You should try polishing that blue anti-glare coating out before replacing it. Search google for "Audi: How to Recondition MMI Display"...I can't link directly.
Unlike the article, I wasn't able to find an LCD cleaner that would also remove the coating, so I recommend using a small polisher/drill attachment and compound. The coating is ridiculously easy to scratch but surprisingly difficult to remove completely by hand. I did it to my screen after rubbing what I thought was some grime and ended up scratching the coating. Literally looks better than new, just no longer blue tinted. Just watch the heat when polishing and pressure, it's glass.
Also be careful not to get polishing compound inside the layers of the panel. If you do you will notice some dark spots in the display when you turn it back on. You haven't broken it...but it's gonna require you to literally take the layers of the display apart down to the plastic sheets for you to clean it out...and every bit of dust at that point will cause some artifacting in the display. Ask me how I know....so be careful not to jam stuff excessively under the bezel around the lcd panel, a bit is totally fine.
But in case that happens to you, this shows you exactly how that panel is built:
https://www.youtube.com/watch?v=jiejNAUwcQ8
Otherwise if you are careful and keep things clean this will literally take an hour or less to do. Nothing is glued, it's all clips (even if you have to rip apart the panel) so just take your time and don't force anything.
Good luck!
