Results 1 to 40 of 77
    Sep 12 2020
    SC
    Recommendation for Brake pads and rotors
    Need a recommendation for a good Brake pad/rotor setup. Regular/non-ceramic brakes
    RS3
    'spirited' street driving with the occasional mountain runs.
    I've searched the forum and Facebook groups but there doesnt seem to be a consensus.
    Thanks in advance
    Established Member Two Rings Porra46's Avatar
    Mar 02 2021
    South Africa
    The OEM pads do a hell of a good job as is. You can look at Brembo pads as they seem to be slightly cheaper than the OEM ones at Audi.
    Sent from my SM-G975F using Tapatalk
    2012 VW Golf Mk6 R - APR Stage 3
    Sep 12 2020
    SC
    Quote Originally Posted by Porra46 View Post
    https://www.urotuning.com/products/f...39606695100609
    these brembo pads are super cheap. not sure if its a mistake or what.
    anyone have experience with them?
    Senior Member Two Rings arulrs3's Avatar
    May 02 2019
    Burlington, NC, Carolinas
    Carbotech 1521 with OEM rotor or Neuspeed 2 piece all around.
    Current DD 2018 Audi RS3 Nardo Grey .. Stage 2 - 93
    VIR fullcourse - 3.27 miles in 2.10.67 minutes.
    10.88 @ 129 MPH - Uni Stage 1+ @ Rockhingham Dragway, NC (70-80 F and DA 1000 ft)
    11.264 @ 121 MPH - Uni Stage 1+ @ Rockingham Dragway,NC (80-90 F and DA +3100 ft)
    11.882 @ 114.80 MPH - Stock ECU/TCU ON 93 @ Rockingham Dragway,NC (50-60 F and DA is less than 1000 ft)
    Past
    2016 VW Toureg TDI / 2014 BMW 328Xd/ 2011 BMW 328i/ 2009 VW Jetta 2.5/ 1997 Nissan Altima
    Established Member Two Rings Nartard's Avatar
    Apr 09 2019
    N.KY
    Little fast wearing, but super happy with Ferrodo DS2500 pads. Quiet, good initial bite, never had a hint of fade. Street and drag use only, no circle track.
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    Just replaced mine. Girodisc 2 piece rotors with Carbotech 1521 pads. No noise (had to really bed them in) low dust great pedal feel.
    Sep 12 2020
    SC
    Quote Originally Posted by andru1313 View Post
    this is the setup im leaning towards at the moment
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I got a great deal on Neuspeed 2 piece rotors and I also did Carbotech 1521. I saved 7lbs per corner on the rotors plus another 7lbs per wheel(Neuspeed RS-10) = 14lbs per corner. Nothing compared to the weight savings of the carbon-ceramic rotors though.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Sep 12 2020
    SC
    Quote Originally Posted by S3DUDE View Post
    where you buying the carbotech pads from?
    Jan 13 2021
    Winnipeg
    I haven't put my pads in yet but have a set of Porterfield R4S I plan to run. Currently on stock brake setup, will see how HPDE school goes this weekend on stock brakes.
    2018 RS3 - Glacier White - JDY NG6670 Build in Progress - IMS Charge pipe/BOV kit, Syvecs Haldex Controller, Uni Dogbone, 034 rear subframe inserts, Catch cans (Iroz engine, 034 DSG), Neuspeed lowering springs & 2 piece front rotors.
    2007 Gallardo Spyder - Eurocharged ECU/TCU Tune, LOC REV5 exhaust
    1993 Mustang LX - GT40 Tubular upper / lower intake, BBK shorties & H pipe, Dynomax catback, Steeda Tri-Ax
    Junior Member Two Rings
    May 17 2020
    My brake light just came on as well. I'm currently leaning toward Neuspeed rotors, simply for money 250-300ish savings over girodisc since I doubt i'll see any track time.
    Anyone have experience with the stoptech sports (309)? I've been debating these and the 1521's.
    May 30 2020
    Montreal, Quebec, Canada
    Speaker of brake light, my light is not always on. Is this normal? I haven’t physically check the wear yet.
    Senior Member Three Rings sleepy_rs3's Avatar
    Mar 29 2021
    New York, NY
    Quote Originally Posted by JOBJOB View Post
    my experience was that it would be on briefly and then off, and eventually it was on full time. basically you have to fully wear through the sensor before the light will remain on full time.
    2019 Glacier White RS3 | Unitronic Stage 2 ECU & TCU | Unitronic Downpipe, Intercooler, & 4" Turbo Inlet | CTS 4" pipe to stock airbox | 034 intake heat shield | DSC Sport Controller | Tyrolsport Deadset Subframe Kit | 034 Street Density dogbone kit | Valentine 1 Gen 2 Radar Detector with JBV1 app
    Feb 17 2018
    California
    Neuspeed 2 piece fronts. Solid performance.
    Aug 29 2017
    Tucson, AZ
    Arelax,
    Paul@supremepower but there are also a couple of other places to buy as well.
    at 3100ft elevation
    Sep 12 2020
    SC
    Arelax,
    thank you
    Mar 02 2021
    South Africa
    I see Revo has a 2 piece disc/rotor available for our cars as well. And their rotors are made by Alcon. They are also 10mm larger in size and a direct replacement.
    https://www.onlyrevo.com/product-det...v-disc-upgrade
    Anyone here know how they compete with the Neuspeeds?
    I see 034Motorsport also make replacements.
    https://store.034motorsport.com/2-pi...-8v-5-rs3.html
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    18' RS3 Stage II and all the Fixn’s
    21' SQ8
    2011 A4 2.0TQ 6MT Stage III
    2001 A4 Stage II
    Feb 23 2019
    Northern, VA
    I am currently running Neuspeed 2 piece in the front with EBC Yellowstuff pads and have been happy with the performance. They have good initial bite on the street and never ran into any fade at a HPDE.
    Veteran Member Three Rings PeteJ's Avatar
    Jul 15 2013
    2017RS3-2014TTS-1967Olds442-2005Chevy2500HD-Duramax%2520
    Waukesha/wi
    Quote Originally Posted by Josey12453 View Post
    I would be very cautious running EBC yellow pads hard on a track. There have multiple failures of those pads when pushed.
    https://www.529innovations.com/
    Finished #13 in One Lap of America 2019 #One0f250]
    https://www.facebook.com/2017RS3/
    The "Go Fast" Car.....
    369" of Oldsmobile power by Rocket Racing
    best of 9.68 @ 136 mph and a 1.242 60'
    http://mbworld.org/forums/signaturep...ic160318_1.gif
    Feb 23 2019
    Northern, VA
    Quote Originally Posted by PeteJ View Post
    Thanks for the heads up. I don’t push my brakes as hard as a lot of people on the track. My goal is to drive the car home, so I take it pretty easy.
    Jun 02 2018
    I really like the Essex/AP Racing front rotors with Ferodo DS2500 combo I have on my car. Very linear with great pedal feel and the DS2500 still works in sub zero Canadian winter.
    They are pricier than the other options but the performance/value is there IMO. You also have the option to add the AP Racing calipers later which save another 6-7lbs per corner and bring the whole braking package to the next level.
    Apr 08 2014
    9400 miles... Light came on. Dealership claims the fronts have 2mm left. How much longer I'm I able to safely drive? Thinking of changing them to neuspeed 2 piece and carbotech 1521 but don't think they will arrive for a week or so but also need a vehicle to get around.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by CdnaudiS4 View Post
    You Can probably go another 1000 miles without issue, for me I just changed the pads, rotors are very robust, it’s just the pos Brembo pads that come with the car.
    Aug 29 2017
    Tucson, AZ
    Quote Originally Posted by Roadtrippn View Post
    Yes, I considered them.
    at 3100ft elevation
    Oct 10 2020
    CA
    I'm currently leaning towards the Neuspeed 2 piece front rotors over Girodisc just because they use stronger 7075 aluminum for the hat (vs 6061).
    For pads I'm leaning towards Hawk HPS 5.0 front and rear. FCP Euro has the front set for RS4, so that means lifetime replacements. If I got these I would cut the wear sensor pigtails off my OEM front pads and make my own bypass adapters so it's fully reversible.
    For the rear rotors I might go with something like the StopTech slotted rotors, since they are also available on FCP Euro.
    Apr 08 2014
    Quote Originally Posted by o1turbo30v View Post
    So for my very first brake change I can just do pads and leave the rotors for next time? What did you end up using for pads? I was told that I had to change both rotors AND pads regardless of when I need breaks done.
    Junior Member One Ring
    Jan 19 2018
    2018 Alpine/Black Optic RS3
    Tuxedo, NY
    No, you typically do not need to replace rotors. They last much longer than pads. I've got 30k on mine and rotors have tons of life in them.
    If you drive very aggressively, you could get damage from hot spots or warping that requires replacement before the rotor material is worn down, but not from typical street use.
    Senior Member Two Rings chi_marketing's Avatar
    Jan 14 2019
    Chicago
    I have the Neuspeed 2 piece front and rear and RSL 29 pads. I can stop on a dime. No shutter slowing down from 140-60. They are noisy when they are broken in.
    https://www.pagidracing.com/en/produ...sl/rsl-29.html
    New light-weight rotors will help with 1/4 times. Ran an 11.9 1/4 over the weekend. Full weight plus a full tank of pump gas. Good times.
    2023 Macan GTS
    2019 RS3
    2019 RS5 Sportback
    Established Member Two Rings steven5210's Avatar
    Oct 24 2018
    San Francisco CA
    Has anyone ordered from here https://www.europaparts.com/brake-pa...0698151m.html? I saw someone mention this and said it was OEM pads also. The pricing is the cheapest I've seen lol.
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by steven5210 View Post
    Yes I’ve bought a lot of parts from those guys, absolutely a go to place. That being said, if you are handy, our cars use the same front pads as a b7 rs4, wear sensors are the only difference, way more options for the rs4 and way cheaper.
    Nov 06 2017
    Vancouver
    https://www.rockauto.com/en/moreinfo...438675&jsn=844
    May 30 2020
    Yeah I’m thinking of buying these. The OEM are fine for my needs and the main reason I am drifting away from buying ECBs is the bedding process. I don’t have time for this!
    As for the person asking for rotor I was too told that rotor last for long. I bought a digital caliper form $15 just to check. Min thickness is 32.4mm and new is 34mm.
    Senior Member Two Rings itr325's Avatar
    Mar 13 2007
    1998 Acura Integra Type-R
    Milwaukee/Wisconsin
    I second this!!! Burnt a setup on a B8 S4 in about 45 minutes at Road America. They are not track pads, you'll want to run the Blues for track days.
    Established Member Two Rings pnice1p's Avatar
    Jul 05 2013
    2023 i4 M50, 2015 JCW MINI
    Fort Lee, NJ
    Quote Originally Posted by Arelax View Post
    I have em. Same pad no Audi stamp. Exact fit and characteristics.
    Jul 01 2020
    NoVA
    Quote Originally Posted by pnice1p View Post
    I tried ordering the cheap Brembo OEM replacements from Urotuning and they messaged me back asking if Zimmerman brand was okay? I was unsure and canceled the order. Do you have Zimmerman pads? I just want to retain the sensor connector and OEM look for warranty reasons. Just street driving, so no need for additional performance/dust.
    May 30 2020
    Same thing for me RichJ haha! Also RockAuto doesn’t have them anymore on the date of this post. So I ended up ordering the pads for the RS4 2008 from RockAuto along with a plug with for the sensor. I’m too dumb to splice wires and stuff like that. I’m gonna check my pads on tire change / rotation anyways.
    Jul 05 2013
    Fort Lee, NJ
    Quote Originally Posted by RichJ View Post
    I got Brembo when I ordered. I ordered three sets cause it was a great price image-2021-05-29-20:19:09-427.jpg
    2020 RS3 - Stage 2 Ecu 93 Stage 2 TCUfrom my iPhone using Audizine Forum
    Mar 28 2018
    Found these on eBay
    https://www.ebay.com/itm/Brembo-Fron....m46890.l49286
    Mar 29 2021
    New York, NY
    How long have you been running those? I ask because the Audi pads have two little round nubs on the back of the plate (see photo). I installed some Porterfield R4S which were said to be a fit on the porterfield website https://www.porterfield-brakes.com/P...field%20Brakes and appeared exactly as the OEM (i changed the pads myself) but without those two little round things. I ordered them because I was pressed for time ahead of a road trip and I wanted an OEM-like pad but for a better price.
    They worked great, then after 8,000 miles I started getting a clunking sound which I thought was a suspension component issue. Audi diagnosed for free and told me it may be due to aftermarket brake pads shifting around in the caliper. I would have sworn that it was a broken strut mount bushing or something (from NYC potholes) but I decided to have them put in the OEM pads, that way if it was a suspension component I would have a shot at a warranty claim. Sure enough it was the pads moving around...I was shocked. The only difference I could tell between the $250 Porterfield R4S' that I used was those two round things on the back. Maybe the pads I used just had poor tolerance, but considering I did lots of high speed driving/braking in the 8,000 miles I had them, I would be suprised if that was the case...my theory is that it's those stupid little nubs.
    Anyway...keep us posted on how those brembo pads work out for you over time. If you hear a clunking in 8,000 miles time at least this post will tell you what it may be. If not, you may have discovered a low cost OEM replacement.
