Results 1 to 9 of 9
    Veteran Member Three Rings prestige.phantom's Avatar
    Jul 16 2018
    Connecticut
    Brake Caliper leaking fluid from connection with brake hose?!?
    Hello all, I have been going through the worst possible brake install of all time. After fixing a series of unfortunate issues, I though I was finally done and bleed the system twice.
    Unfortunately this presented another issue, which I was wondering if anyone knew how to solve?
    The front S8 brake calipers appear to be leaking fluid out of the connection with the front brake hose. I dont recall any issues when installing the hose, so my concern is that the connection thread is stripped. Anything else I should check / try before I start looking around at machine shops to fix the caliper? Any help would be greatly appreciated.
    Thanks!!
    2013 Audi A6 3.0T Prestige
    | Phantom Black Pearl | Nougat Brown interior | LED Headlights | Cold Weather PKG | 20" Sport PKG Wheels & 3 Spoke Heated Wheel | Fine Grain Ash Natural Inlays | Michelin Pilot Sport AS3+ Y | OEM "Rings" Puddle Lights |
    | AWE Touring Exhaust | JHM Non-Res DPs | Eibach Pro Kit & Bilstein B4 Sport Shocks | Eurocode Trans Mount | JBX Carrier | S8 Front Brakes w/ EBC Red Pads | 034 ECU 93 STG 1, TCU, Rear Swaybar, and Endlinks |
    IG: @prestige.phantom @ctautoart
    May 20 2010
    How tight (or not) did you thread that connection in? Loosening the one on the old caliper will give you an idea how tight it needs to be?
    And when you installed the hose, did you turn it left to seat it before turning right to tighten it? (i.e., not cross-threading).
    PS: I am sorry to hear about all your issues!
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jun 18 2017
    10512 Hunter Trl/Illinois/
    Do a visual check of all attached items at that junction. Check threads on brake hose for cross threading, check caliper for collapsed threads - due to cross threading. Lastly, check the caliper for hairline cracks at brake line mounting point. First two scenarios are easy to resolve, cracked caliper not so.
    Mar 05 2013
    CA
    I would check the threads
    Jul 16 2018
    Connecticut
    Itt was tight, but I was careful not to over tighten it. I did not turn it left before turning it right. I was unaware that was how you were supposed to do it...
    - - - Updated - - -
    Quote Originally Posted by Spike00513 View Post
    This is my worry exactly...
    - - - Updated - - -
    Planning on carefully removing the hose today, and inspecting the threads. If they dont look too bad then I am going to try to reinstall the hose and see if it leaks again.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Pull it back apart and check the threads for sure. Check the seat on the caliper where the sealing surface is. Might be a problem with caliper itself.
    I just looked at some pics of S8 hoses and it does not appear that the threads seal anything. The sealing surface is the flared end. You have a bad hose end, possibly not tight enough, or crap in the seat, or possibly the wrong hose with the wrong flared end. The angle on the hose end must match the caliper seat angle.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Valpo A7 View Post
    Is it my imagination or do the exposed threads look off-angle? If the caliper was already mounted when you were fixing the hard line, could some debris have gotten in? Keep at it!
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Nov 27 2018
    Valparaiso, IN
    Quote Originally Posted by Alabama View Post
    Possibly.
    It’s hard to tell from this pic and I am on my phone so I am looking at a postage stamp of a picture. Plus the caliper is at an angle and the camera is at an angle so it might look deceiving. From pics of new hoses I don’t think that the hose would have gotten this far into the caliper being cross threaded. It should have been hard to turn well before the end gets seated.
    Jul 16 2018
    Connecticut
    The threads were pretty poor. I am having it professionally repaired. Will update if this fixes the issue.
