View Poll Results: TSI bearing cam follower
Voters
4. You may not vote on this poll
  • It works!
    3 75.00%
  • Worth trying
    0 0%
  • Not advisable with K04 Stage 3
    0 0%
  • IDK
    1 25.00%
Results 1 to 32 of 32
    Senior Member Two Rings arankaspar1's Avatar
    Feb 20 2018
    Oakland CA
    Updated TSI follower conversion kit on FSI engine
    Has anyone ever tried this conversion? I'm wondering if I can get the TSI rolling cam follower with the bearing, but keep my HFPP?
    Seems like it would help with follower service intervals but I don't know how it would hold up with a K04 stage 3 tune.
    https://xlr8performance.com/i-37337-...2-103-107.html
    https://www.ecstuning.com/b-iabed-in...-103-107slrkt/
    Feb 15 2016
    Cambridge,Ontario
    It's been done quite a few times. Not sure how to search it though.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Mar 24 2013
    Oakdale, CT
    You can use the same hpfp with the kit. I’ve been running it for well over a year (probably closer to two) with no issues. I’m using the same IE hpfp I was using before installing the roller follower.
    -Adam
    Established Member Two Rings KingKostas's Avatar
    Oct 13 2017
    Long Island, NY
    u keep the same hpfp, i run the iABED conversion for over a year no issues
    Feb 20 2018
    Oakland CA
    Quote Originally Posted by KingKostas View Post
    Are you stage 2 / 3?
    Feb 20 2018
    Oakland CA
    How often should you check the roller style?
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quite a few people run it. Just gotta decide if its worth spending $600, to save from changing a $15 CF every 10-20k miles. Even every oil change(5k), would take a long time to pay for itself.(40x)...
    Sent from my LM-G710VM using Audizine Forum mobile app
    Jun 27 2011
    You basically don’t need to check the roller because of the nature of how it works.
    Maybe at high levels of tune you could check it every few oil changes if you’re nervous but I’m pretty sure it’s not a common failure item for the b8 guys even when they’re tuned.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Dec 25 2017
    Sweden
    I did a comparison in my build thread between brands. You can reduce cost by sourcing some of the parts yourself. So that’s what I did, granted my engine isn’t running yet so we’ll see how it goes.
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I have complete roller conversion looking to sell it. Has about 8 minutes of run time on it.
    Account Terminated Four Rings
    Oct 15 2013
    Quote Originally Posted by canadianA4B7 View Post
    If you don't mind me asking, why are you selling it?
    Oct 24 2015
    Perth, WA
    how much to my town? :)
    My respray thread
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by Okedokey View Post
    It’s already sold. Sending it out Monday/Tuesday to it’s new home.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by arankaspar1 View Post
    I’m somewhere beyond stage 3...
    I really only check the roller follower when I have it apart for other reasons. I have seen no indication of wear so far in ~15k miles.
    -Adam
    Oct 13 2017
    Long Island, NY
    big turbo. i never check my follower
    Jun 13 2017
    nowhere
    i never check my followe either... but I have to guess now that people have so many issues with them because of dirty oil and as soon as it doesnt have the clean lubrication it needs, thats when the small cracks happen and then the thing shatters inside for total failure.
    change oil and disable your balance shafts and everything will be fine.
    Feb 20 2018
    Oakland CA
    Quote Originally Posted by blakefife View Post
    Disable your balance shafts? Seriously? Why?
    Feb 20 2018
    Oakland CA
    I am also curious why you were selling off the conversion kit?
    Feb 20 2018
    Oakland CA
    Quote Originally Posted by Jayz691 View Post
    True but this guy did it on the cheap by having the original housing machined out...
    https://www.youtube.com/watch?v=GZrN52cI7V4
    Also every time you remove that f*ing HPFP the Aluminum to Aluminum bolts/cover weaken a little more each time. I'm already at the point where I've slightly overtightened 1 of 3 bolts and it makes me very nervous.
    Feb 10 2012
    parts
    Napanee, ON
    2.0 go bang. No more interest in the money I’ve already wasted on their engine. Cut losses, learn from shit that happens.
    Invest in torq wrench. Should be no fears if you wrench to spec. Being the materials differences I cannot understand why one would take risks. Too ditch the Audi bolts for 12.9. Rather then throwing bolts away every change just use torq wrench.
    Oct 15 2013
    LOL
    Follower failures are due to aftermarket pumps pushing more volume and thus increased wear on the follower. The vendors all recommend more frequent follower changes with their high performance HPFP compared to stock.
    My stock OEM 60,000 mile follower had as much wear (very little) as my high performance HPFP follower after 10,000 miles.
    Frequent oil changes with the best oils or balance shaft deletes will not reduce the wear as simply as you think, especially with aftermarket HPFPs.
    The whole balance shaft mania is nonsense. It's an inline 4 cylinder engine. It needs counter weights to balance. Too much vibration is bad..
    Jan 21 2018
    frackville, pa US
    He doesn't even mention cost. But yes, there are multiple kits available, that you need to machine the housing yourself. But theyre still not cheap, and add in cost of machine shop. Ones ive seen were $300-$400. Some come with uprated cam lobe, some don't. Unless you have tools at home to do it. The pump and bolts were never an issue for me. I use a mini ratcheting bit driver, so I CANT tighten it too much. Or torque to spec if worried. Not an issue unless you crank on em. I'll just change the $15 follower every 10k miles. Would last much longer with a new cam. Car had signs of previous follower failure when I got it. Cam isn't real bad, but its scratched up a little.
    Jan 07 2021
    2000 New Beetle, 2007 A4 Cabriolet, 2010 A3 S-Line
    California
    I believe that's AudiB720TS who posted above. As for the threads stripping out you could switch to studs...
    In the process of de-beatering a 2007 A4 Cabriolet
    Dec 25 2017
    Sweden
    Yes, my video.
    I did a table comparison showing the cost of all known options out there. It should be in my build thread. If not I can post it again.
    The DIY is going to be cheaper than the rest, but it’s also a major headache to sort and there’s of course the ‘opportunity cost’.
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    I have it done. I'm like Stage 14+ or something like that. I never check to see if the follower is worn anymore. It is noisier than the stock one but its just something to be aware of.
    Jun 27 2011
    I’m stage -2 and I use a wooden cam follower. When I need a new one I saw off a limb of the apple tree in my backyard and whittle a new one out if it with a pocket knife. It lasts a super long time!
    -CP
    2017 Q7 3.0t
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by i3oricua View Post
    Same here. I can’t really say it’s noisier really, but it does sound different.
    -Adam
    Jun 13 2017
    nowhere
    Hey chump, just checkin in with ya. Been over a year now driving around with my balance shafts disabled and havent checked my cam follower because guess what? I have clean oil and the engine sounds fantastic.
    LOLOLOLOL
    Your whole ego mania is nonsense. Try not being an egotisitcal maniac wherever you go, even online like these forums. clown boy.
    Jun 13 2017
    nowhere
    Quote Originally Posted by esandes View Post
    LOL
    LOLOLOLOL
    Jan 21 2018
    frackville, pa US
    LOLOLOLOL
    He's not even on here anymore. Look at his profile, "account terminated"(thank god). But there is a lot more to follower wear than oil changes. Biggest ones being intake cam revision, and preformance level. On a stock car thats running 119bar max rail pressure, theres not as much stress as say running 140bar(k04). Hpfp upgrade brand/design matters, and driving style. But like anything, clean oil is always good...
    Feb 15 2016
    Cambridge,Ontario
    esandes is finally gone ? well that alone should save a few engines.
    I think Engine oil visible dirtiness so quickly on this platform is more related to DI than anything else.
    it seems very common on all DI engines for oil to turn black quickly
    doesn't speak to properties though..
    1976 Yamaha XS 360
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    These two posts lmao
    "Beep beeeep bloop boop" - R2D2
