Results 1 to 29 of 29
    Veteran Member Three Rings MTV10's Avatar
    Apr 29 2020
    Montreal
    Driver's Side Key Hole
    I'm slightly OCD - and the key hole on the driver's door annoys me. It stands out and looks unrefined.
    Does anyone know of a 'Plug' that anyone sells that we can stick in there? Or maybe fitting the rear cap to the front?
    Worst case I'll paint it....
    2018 /S6 | Mythos Black / Arras Red | Stage II ECU | APR TCU | ARM Downpipes | AWE Touring Exhaust | SRM Intakes | CETE Lowering Module | 034M DSG Mount Insert | HRE P43SC
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    I would recommend paint over a plug because at some point your key fob battery will probably fail.
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    maybe buy a spare plug, fill the hole with body filler or whatever, paint the cap and reinstall, that way if you ever really need to use the key you can pop the cap off
    https://youtu.be/a-YrJsFAkrU
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Established Member Two Rings 5000S's Avatar
    Aug 26 2020
    You are OCD, that key hole has a purpose, and that is it allows you to get into your car with a key.....as mentioned with a lockout or other it is necessary.
    Wanting to put a plug in it, is simply stupid. I can tell you deal with a lack of experience......
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    i dont recall him asking for a permanent plug. a removable one would be nice for sure
    Apr 29 2020
    Montreal
    I ordered a second cover off amazon - will have it filled and painted then install in place of OEM one.
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Is the passenger cap universal and can be flipped? This way no filling, just painting a new one.
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    i used them for the wiper arm block-off plug on my 996tt back in the day...
    https://bumperplugs.com/index.php?route=common/home
    2016 S6 - sport - optx- atlas - AE nardo
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    Quote Originally Posted by MTV10 View Post
    Take rear cap and have it painted. I do it to all my cars that's setup this way for the shaved key hole look.
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    Apr 29 2020
    Montreal
    Quote Originally Posted by 5000S View Post
    I like to call it CDO ... alphabetical order ;)
    As for lack of experience - you're lacking style, pal. Stupid is letting your key fob battery run out - especially since this car warns you months in advance when charge is low.
    Quote Originally Posted by bonafyd View Post
    Looks so much cleaner. It's all in the details!
    Veteran Member Three Rings bpd's Avatar
    Feb 01 2017
    Seattle WA
    For me I like it. Did that to a couple of my old Acura's just buying the rear door cover. Didn't know the rear one fit the keyed cover on our Audi's. It puzzles thieves who like to use a screwdriver to force the lock. Technique called "punched lock."
    2018 S6, 2023 S5 SB
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Those potholes can't be good for those tires.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Sure, but the way my luck goes, something happens to the vehicle electrical system and the battery in the trunk dies. What then?
    Apr 29 2020
    Montreal
    Unlock the car via the trunk and crawl through.
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    No doubt I'm showing ignorance but I thought the 2014 S6 does not have a lock cylinder on the outside to open the trunk, only squeeze button, "kicking foot" sensor, and remote key. If the electrical system fails then none of those will work to open the trunk. There is the emergency release inside the trunk, but that doesn't help here. What am I missing?
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by Alabama View Post
    Nothing other than he's dumb. Plus, the battery itself is in the trunk, and how are you getting the seatbacks down from inside the trunk? Avant model notwithstanding.
    Foolish on its face.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Feb 01 2017
    Seattle WA
    Making this way too hard. If you do replace the keyhole cover with a closed one, it is just as ez to remove as it is to install. When I did this with my Acura's, the part came painted. So this simple mod was super ez.
    2018 S6, 2023 S5 SB
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by bpd View Post
    Right! It's got to be easy to remove, just in case. Do you happen to know what is the Audi part number for the cover? Does it just snap on, like the cover over the tow hook in the front bumper?
    Apr 29 2020
    Montreal
    I was being sarcastic. Just remove the key hole cover and open the door.
    Quote Originally Posted by GilliamOS View Post
    You're the foolish one. Read between the lines buddy.
    Exactly.
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    know whats funny ......i never really even noticed it much that there was a key hole there but after reading this i see it all the time....thanks jerks lol
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Jan 29 2019
    St. Petersburg, FL
    Quote Originally Posted by paul-g View Post
    I'm in the same boat, I've never even noticed it. I'm scared to look now, lol
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    I am very detail oriented when it comes to the appearance of my cars, inside and out. It gets on my wife's nerves that my car is always spotless yet I don't really care about other things around the house to the same degree.
    That said, I've NEVER even noticed the key hole---not on this or any other car.
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    This ^^^^
    Now I have to fix it, no other choice. However, I highly doubt when I am filling my car up, someone will come up and compliment me on my keyhole mod.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Apr 29 2020
    Montreal
    Anybody have the part number for the rear cover?
    Nov 27 2008
    New Jerz
    4H0-837-880-GRU
    Feb 01 2017
    Seattle WA
    Depends if you have chrome or not on that part, but I believe the part # is 4HO837879GRU. That is for left side rear with no chrome
    2018 S6, 2023 S5 SB
    Apr 29 2020
    Montreal
    This was the correct part #
    Before and After. Very happy... much cleaner look.
    Feb 01 2017
    Seattle WA
    How did you get it painted? Looks good and clean. Getting it painted is my biggest barrier.
    2018 S6, 2023 S5 SB
    Apr 29 2020
    Montreal
    Body shop that I know. $20 - perfect match.
