034Motorsport Tuning and Hardware Information + New Product Info
In this post, we will talk about the products that 034Motorsport offers for the 8V A3/S3 platform to enhance the performance of the 2.0T engine, and the chassis as a whole. We are here to offer an extensive product catalog of Substantive, quality parts that provide measurable improvements to your enjoyment of your car, so that you can kick ass at a drag strip, track day, or autocross event, and drive the car to work the next day with comfort and confidence. Below will be some links to the products we offer, as well as upcoming products you can expect to see in the future. If anyone has questions about products, feel free to use the comments as a place to discuss.
PRODUCT LINKS
TUNING FOR A3
034Motorsport Dynamic+ ECU Tuning for Stage 1: CLICK HERE
034Motorsport Dynamic+ ECU Tuning for Stage 2: CLICK HERE
034Motorsport Dynamic+ TCU Tuning for DQ250-MQB: CLICK HERE
034Motorsport Dynamic+ Flashing Cable: CLICK HERE
TUNING FOR S3
POWERTRAIN
034Motorsport X34 Carbon Fiber Closed-Top Cold Air Intake: CLICK HERE
034Motorsport X34 Carbon Fiber Open-Top Cold Air Intake: CLICK HERE
034Motorsport X34 Carbon Fiber Fresh Air Duct: CLICK HERE
034Motorsport P34 Cold Air Intake: CLICK HERE
034Motorsport Insuction Bundle: CLICK HERE
034Motorsport Turbo Inlet Pipe: CLICK HERE
034Motorsport Cast Stainless Steel Racing Catalyst Downpipe For FWD: CLICK HERE
034Motorsport Cast Stainless Steel Racing Catalyst Downpipe For AWD: CLICK HERE
034Motorsport R460 Hybrid Turbocharger System for S3/GolfR: CLICK HERE
034Motorsport Billet Catch Can Kit: CLICK HERE
034Motorsport Silicone Boost Hose Kit: CLICK HERE
034Motorsport Billet Aluminum Rear Main Seal: CLICK HERE
CARBON FIBER
034Motorsport Carbon Fiber Fuse Box Cover: CLICK HERE
034Motorsport Carbon Fiber Engine Cover: CLICK HERE
034Motorsport Carbon Fiber Battery Cover: CLICK HERE
034Motorsport Carbon Fiber Engine Cover Package: CLICK HERE
SUSPENSION
034Motorsport Dynamic+ Lowering Springs: CLICK HERE
034Motorsport Street Density Strut Mount: CLICK HERE
034Motorsport Billet Rear Subframe Mount Inserts: CLICK HERE
034Motorsport Dynamic+ Solid Front Sway Bar: CLICK HERE
034Motorsport Dynamic+ Solid Rear Sway Bar: CLICK HERE
034Motorsport Dynamic+ Solid Rear Sway Bar for RS3: CLICK HERE
034Motorsport Motorsport Front End Link Pair: CLICK HERE
034Motorsport Dynamic+ Front End Link Pair: CLICK HERE
034Motorsport Motorsport Rear End Link Pair: CLICK HERE
034Motorsport Dynamic+ Rear End Link Pair: CLICK HERE
034Motorsport Density Line Rear Adjustable Control Arm Pair: CLICK HERE
034Motorsport Motorsport Rear Adjustable Control Arm Pair: CLICK HERE
034Motorsport Spherical Rear Trailing Arm Kit: CLICK HERE
034Motorsport Density Line Adjustable Rear Toe Link Pair: CLICK HERE
034Motorsport Motorsport Adjustable Rear Toe Link Pair: CLICK HERE
034Motorsport Front Subframe Locking Collar Upgrade: CLICK HERE
034Motorsport Street Density Rear Shock Mount: CLICK HERE
034Motorsport Dynamic+ Camber Mount Pair: CLICK HERE
034Motorsport Strut Mount Bearing: CLICK HERE
034Motorsport Dynamic+ RCO (Roll Camber Optimizer): CLICK HERE
034Motorsport Dynamic+ RCO Control Arms: CLICK HERE
BRAKES
034Motorsport Stainless Steel Braided Brake Line Kit: CLICK HERE
034Motorsport 2-Piece Floating Brake Rotor Upgrade Kit (340mm): CLICK HERE
034Motorsport 2-Piece Floating 350MM Rear Brake Rotor Upgrade Kit: CLICK HERE
034Motorsport Front Rotor Ring Replacement Set: CLICK HERE
034Motorsport Rear Rotor Ring Replacement Set: CLICK HERE
WHEELS
034Motorsport Forged Single-Piece ZTF-01 18x8.5 ET45 57.1CB: CLICK HERE
CHASSIS
034Motorsport Stainless Steel Tow Hook: CLICK HERE
034Motorsport Billet Dogbone Mount Performance Pack with Pucks: CLICK HERE
034Motorsport Billet Dogbone Mount Performance Pack without Pucks: CLICK HERE
034Motorsport Billet Spherical Dogbone Mount: CLICK HERE
034Motorsport Billet Spherical Dogbone Mount for DQ381: CLICK HERE
034Motorsport Billet Dogbone Mount Performance Pack without Pucks for DQ381: CLICK HERE
034Motorsport Billet Dogbone Mount Performance Pack with Pucks for DQ381: CLICK HERE
034Motorsport Billet Upper Dogbone Mount Insert: CLICK HERE
034Motorsport Billet Lower Dogbone Mount Insert: CLICK HERE
034Motorsport Street Density Dogbone Mount Pucks: CLICK HERE
034Motorsport Density Line Motor Mounts: CLICK HERE
034Motorsport TrackSport Engine/Transmission Mount Pair: CLICK HERE
034Motorsport StreetSport Engine/Transmission Mount Pair: CLICK HERE
034Motorsport StreetSport Engine/Transmission Retrofit Kit: CLICK HERE
034Motorsport Density Line Engine Cover Grommets: CLICK HERE
EXHAUST
034Motorsport Res-X Resonator Delete: CLICK HERE
UPCOMING PRODUCTS/TUNING OPTIONS
We will use the comment section to share photos of upcoming products as they go through development, and add the links to the main post once they become available.
- Static Camber/Caster Camber Plates
- Dynamic+ Lowering Springs for Non-Magride (A3)
- Ethanol Blended Tunes
- Hybrid Turbo Tuning Options (EQT)
- Full E85 Tuning Support
- Advanced Launch Control
- X34 Carbon Fiber Intake (Open Design)
- Billet Rear Main Seal
- DQ381 Tuning
