Results 1 to 40 of 50
    Feb 27 2020
    Any Engine Swap Options?
    I've looked all over the place, and I can't seem to find any examples of B8.5 Q5 3.0T's (or any Q5's for that matter) with engine swaps. Is it even possible? You'd think one could fit the 3.0 from the Macan into the Q5, as it's the same platform.... right?
    Anybody have any answers/intel?
    | 2016 SQ5 | Mythos Black Metallic | CTS Turbo Open Air Intake | HRE FF01 | KW V1 Coilovers |
    | 2015 Q5 3.0T | Mythos Black Metallic | APR Stage 1 | RIP 7/16/20 - 10/4/23
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Quote Originally Posted by mvnsory View Post
    The only intel I have gathered is the 4.0T V8 is looking promising. There have been a few 4.0T swapped B8 S4 now and 034Motorsport just announced they have a working 4.0T swapped S4 shop car they are actively working on for developing parts. Nothing specific to the the Q5 platform yet but anything that works for the S4 should absolutely work with/fit in a SQ/Q5. Plus we already have a ZF8 which Audi has mated to the 4.0T on other platforms.
    Sent from my SM-N986U using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Jul 31 2016
    PA
    With the right engineering and resources you can fit whatever you want in there. My friend stuck a VR6 engine with a turbo and a 6 speed from a 350z into a chevy s10 pickup.
    It really just depends on how much money you want to spend. As stated, the 4.0T motor has been done a couple of times and 034 is working on a lot for the S4, but expect that to take a while before it's ready.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Mar 07 2020
    Minnesota
    From my reading, the biggest challenge is going to be the electronics, even if all the mechanical and packaging issues could be sorted.
    Personally I find the 3.0SC is the 'gem' that makes this platform worth owning. I wouldn't trade the 3.0SC's reliability for the 4.0T's power. My buddy has that V8 in his RS7 and he's at the dealer for repairs 3-4 times a year. I'd rather switch to an entirely different platform than put up with the headaches of such a swap.
    I suppose .. if one had a Q5 with a bad engine and a spare 4.0T laying around .. and had a long winter with nothing else to do ..
    Jan 08 2016
    Los Angeles, California
    Is the Macan 3.0 any different other than tuning? Why would you replace a 3.0 with another 3.0?
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Jul 31 2016
    PA
    Quote Originally Posted by Pittdawg View Post
    That's a turbo engine I think, I didn't think the supercharged one was used in the Porsche.
    And yeah, electronics would be a problem, you may end up needing to run 2 ECUs.
    Veteran Member Three Rings Clun9's Avatar
    Oct 09 2008
    B8.5 S4, SQ5 & Unicorn 337
    Quote Originally Posted by RoofRails View Post
    Nick has been sending out teasers. I am looking forward to seeing it in person haha.
    MK4 337 GTi (custom widebody) | Bagged B6 S4 (SOLD BUT NOT FORGOTTEN) | B8.5 S4 (STOLEN & TOTALED) | Dual Pulley B8.5 SQ5
    Apr 29 2018
    Quote Originally Posted by djn876 View Post
    Could you imagine a SQ/Q5 making Turbo VR6 noises ! That would be glorious !
    Jul 31 2016
    PA
    I want to do it to my wife's Atlas that has the V6 in there.
    Feb 27 2020
    I was thinking more power, or a different setup maybe. The Macan's 3.0 would get rid of any issues regarding displacement. A man can dream, right? haha
    Jul 16 2019
    Denver
    Single turbo V6 instead of our supercharged v6.
    '16 Q5 3.0T - 034 Stage 2 Single Pulley, TCU Tune, 034 Inlet Pipe, JHM HE, AFE Dry Flo, RS7 Mod Airbox, 11385 Resonated X
    '19 Mustang GT - PP1, Active Exhaust, Steeda X Pipe, Steeda Clutch Spring
    Sold: '13 Golf R - Unitronic Stage 1, Neuspeed Intake, USP Motorsport SS Lines, Stoptech Rotors/Pads, RBF600 Fluid, ECS Copper Shift Bushings, OEM Euro Tails, Non Resonated 3" Catback, Sparco Wheels
    Apr 29 2018
    There was a guy on one of the Facebook groups that had a 2.0T that was giving him issues and he was talking about going with a normally aspirated 4.2 V8. I thought that would have been a really cool swap. That V8 makes all the right noises and would definitely have been quicker then his 2.0T. I don't think he went through with it though.
    Sent from my SHT-W09 using Audizine mobile app
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    The platform is the same but everything else is different, engine, gearbox ........
    You have to replace: engine, gearbox, electronics, you have to find who will adapt the software to the existing modules in Audi, of course everything is possible, but the price of this project is certainly 15k-25k or more.
    Only the key electronics and adjusting the ECU protection system would cost around 2k-3k and....and.....
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I want to put a 6MT into a B8 SQ5........
    Oct 29 2005
    10speed
    San Francisco, CA
    If you think about the Q5 basically being a B8, anything from that range should fit. RS5 V8 would likely be an easy drop-in, but the 4.0TT will probably become more popular over time too.
    - Clint
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    +1 for 4.0T
    here's some inspiration- this dude put the RS5 4.2L V8 in his allroad https://www.instagram.com/makisupaa/
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Apr 29 2018
    Quote Originally Posted by q5 dave View Post
    +1 for 4.0T
    That is absolutely a sick build !!
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    The engine is totally different. Different bore and stroke, different block, heads, cams, everything. Turbo induction. Only thing in common is that both are 3 liter V6 engines. I doubt you can make much more power with the Porsche engine, anyway.
    Better choice would be our 4.0TT if it could be shoehorned in somehow.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Mar 07 2020
    Minnesota
    Quote Originally Posted by S4'ed View Post
    I was just thinking about that the other day, after looking at a B8.5 S4 with a 6spd ... I wouldn't be surprised if the drivetrain things work OK but the ECU and the clutch stuff would be challenging.
    Feb 27 2020
    +1 for 4.0T
    That Allroad is absurd! Thanks for sending the link
    Jul 25 2009
    Bellevue, WA
    Quote Originally Posted by MSq5 View Post
    depends on which gen macan you are talking about.
    we have a gen1 and it has the Porsche 3.0tt. I'm nearly certain it's a twin turbo. That said, I prefer our 3.0SC to that engine. It's laggy and lazy. Not nearly as punchy as our 3.0SC
    the gen2 macan s has audi's single turbo 3.0. the macan gts and turbo have the TT version of audi's 2.9
    '16 SQ5 ROW/BilsteinB8 CH-R 9s; 997.2 spasm 6spd; '18 Macan S. Many, many audis in the past...
    Oct 09 2008
    Quote Originally Posted by Norskie View Post
    It's been down. There was one for sale in CA awhile back. A few people have done it in the EU as well.
    https://www.roadandtrack.com/car-cul...swap-for-sale/
    Oct 10 2010
    Sarajevo, BiH
    Quote Originally Posted by Clun9 View Post
    I have to disappoint you, this is a great lie and deception and now I will explain to you why
    The Q5 model for the EU market was fitted with a 6-speed manual transmission, but only in the weakest engines, with OB2 markings that can withstand a maximum of 350 Nm of torque.
    As is known the SQ5 3.0TFSI has 470 Nm
    Imagine what would happen to this gearbox during the first acceleration with maximum throttle
    Of course Audi has a 6-speed manual transmission that offers a much higher Nm, more precisely max torque 500 Nm, but it was installed in the S4 / S5 but never in the Q5
    Oct 09 2008
    I am well aware that they aren't the same trans in the 2.0T manuals.
    US based SQ5s are 3.0T TFSI only. Q5s are also optioned with 3.0Ts here.
    The example for sale was a local here in the SF Bay Area. The description from road and track was not completely accurate. But the vehicle for sale, was in fact a 3.0T, 6 speed swapped SQ5.
    Oct 29 2005
    10speed
    San Francisco, CA
    I wouldn't be shocked if the B8.5 S4 manual parts bolt right up
    - Clint
    Oct 10 2010
    Sarajevo, BiH
    Both models 3.0 TSFI 272HP 400 Nm or 3.0TFSI 354HP 500Nm they have a much higher torque of 350Nm, which can withstand a standard manual transmission from Q5
    Conclusion, it is technically impossible that it is a manual gearbox from Q5, only possible that it is from another model, then the information in the above text is not true
    Established Member Two Rings Hcw484's Avatar
    Aug 25 2020
    Central Jersey
    Anything is possible with enough money lol.
    4.0TT seems to be the common choice for donor engine with the S4s.
    2016 SQ5 Glacier White | Diamond Nappa | AWE Carbon S-Flo Intake | AWE Touring Exhaust | AWE Non-Res DPs | APR CF Inlet tube | 034 X Brace | 034 Drivetrain Mount Insert Package |
    Oct 09 2008
    Quote Originally Posted by spijun View Post
    Like I said before the Road & Track article is in accurate, but the vehicle is still a 6-speed swapped 8R with a 3.0T.
    You do realize that even in the B8/B8.5 S4s the manual transmissions as is have a hard time of holding the torque right?
    Ask anyone with a B8 S4 with even a stage 1 tune, they will tell you an upgraded clutch and flywheel are basically MANDITORY.
    On top of that, a lot drivetrain parts are inter-changable between the 8R Q5/SQ5 to the B8/B8.5 S4.
    Feb 14 2017
    Gulfport, MS
    I was thinking about a 4.0TT/ZF8 transplant (the beefier 90 series ZF8 from the RS6).
    Oct 10 2010
    Sarajevo, BiH
    Please read carefully
    The transmission is an original Q5 unit imported from Germany
    The original manual transmission that Audi installed in the Q is version 0B2 0B2 = 350 Nm of torque
    Basically A4, A5, Q5 are made on the same platform, most parts are the same
    The CTVA, CTUC, CTXA and CTUD engines are the same 3.0TFSI engines installed in the Q5 / SQ5
    Engine Code: CTUC, CTVA - 200kW (272HP) and CTUD, CTXA -260kW (354HP)
    Model S4 / S5 have a CTUB 333HP engine
    You mention that an upgrade was needed clutch and flywheel are basically MANDITORY, of course and do you know why because model S4 as factory had a torque of 440 Nm and that gearbox had a limit of 500Nm
    Here you can read something about these engines, these are posts from 2013/2014
    https://www.audizine.com/forum/showt...=1#post8994800
    https://www.audizine.com/forum/showt...=1#post9477492
    Conclusion for the end: the text in www.roadandtrack.com for Q5 is not true because there is no original manual gearbox from the Q5 model that can be installed in combination with the 3.0TFSI engine regardless of the 272HP or 354HP version
    Jul 31 2016
    PA
    He's saying use a 6 spd from a B8/8.5 s4 that was made for this engine. Not a manual from a Q5.
    He's also saying it's been done and the car didn't blow up, so you can't really say it's a lie?
    Oct 10 2010
    Sarajevo, BiH
    Maybe I see poorly or don’t understand. Maybe I should see an eye doctor
    My first and all subsequent comments relate to the text that a manual transmission is built into the SQ5
    Sep 24 2014
    Central NJ
    I would use a 6MT from a donor S4, from a USA junkyard. Why would the guy have gotten a 6MT from Germany??
    Oct 09 2008
    Again... you are just copying the words out of Road and track which is NOT where the original vehicle was even listed LOL.
    Again, I have said the Road and Track magazine article is NOT accurate. The original posting was in a craigslist for sale ad that was here in the SF Bay Area. The car was swapped, running and ultimately someone else bought it. Couple of other things in the build that are also strange for the build are the 4 spoke steering wheel, non-sport Q5 seats, the climate controls were from an early Q5 and not an SQ. All these things were just a few things that stood out at me in the original craigslist ad that I saw YEARS ago.
    On another note, I am pretty sure I am familar with the B8.5 S4. I have one... along with my SQ5.
    Oct 10 2010
    Sarajevo, BiH
    This is your post and your link, not mine
    https://www.audizine.com/forum/showt...1#post14501406
    I just replied that it was impossible and attached evidence to you
    Good luck
    Jul 31 2016
    PA
    ^While ignoring literally everything he is telling you lol.
    Oct 09 2008
    Lol SMH.
    Anyway. Yah we know its do-able and been done. Would love to see someone else do it as well.
    That being said, I wonder if 034 is use a ZF with their 4.0TT.
    Jul 31 2016
    PA
    Lol SMH.
    In their post I think they said they are using a DSG for now, the ZF should be an easy swap though since it's already been mated from Audi.
    Oct 09 2008
    Right. From what I remember when they bought the car from the PO, the original trans and engine were parted out. It was basically a shell when they fitted the 4.0TT to it.
    I'm not sure if they DSG is able to hold that torque along with that 700hp.
    Oct 10 2010
    Sarajevo, BiH
    DSG vs S-tronic
    DSG is used in VW vehicles
    VW is using a transverse DSG,
    Audi longitudinal S-tronic
    DSG exists with six and seven speeds, the S-tronic is only with seven speeds
    S-tronic is classified as OB5 and can withstand up to 550Nm
    https://www.audi-technology-portal.d...es/s-tronic_en
    PS: There is also a special version for the R8 and Lamborghini Huracan but this is another category (3 times more expensive than the standard S-tronic EUR 23k vs EUR 7.5k)
