I have read a lot of the threads about timing chain issues, but I don't totally understand what is necessitating the engine out replacement of the entire chain. Please correct me if I'm wrong or elaborate as needed. The issue with the earlier 3.0t engine is with the timing chain tensioners, which the TSB calls out and there is an upgraded tensioner available. The tensioner can be replaced without removing the engine, so would it make sense to proactively replace the tensioners or why can't you just replace the tensioners once they eventually go bad? Again, please explain what is necessitating the engine out replacement of the whole chain and any other relevant info I am missing. For some context, I am having timing cover gaskets replaced under extended warranty and am debating proactively replacing the tensioners out of pocket so as not to have to roll the dice down the road on whether or not the tensioners go bad while under warranty. Thanks for any info/advice.
