Originally Posted by
MikTip
P2270 is the code for the O2 sensor signal stuck lean
Meaning the 02 sensor spacer is causing the 02 sensor to not get full reading.
The S3 is a ULEV. Ultra Low Emission Vehicle. You cant trick fuck it into passing emissions.
Only way to pass is with the stock cat in place.
I passed emissions last year, so i know it can be done. I was thinking about that code last night and had some thoughts.
As mentioned above P2270 means its not getting full reading or spacer is pushed too far out, so Adding more gap as mentioned in post above would not be the answer.
My car runs an aggressive tune with Crackles and pops which means it dumps a little more fuel. When I took the sensor out, it looked to be quite a bit dirty with noticeable carbon buildup.
I cleaned it up and am hoping it works.
If it does not work, I would expect a different reading, maybe even P2271 (stuck rich). If I do not get a different reading, I will place the sensor directly onto the downpipe. If nothing happens still, then I have to assume that its a bad sensor.
7/29/22
Test 1:
*Cleaned sensor, and started over.
*Drove 10 miles, Car cooled off for several hours
*Drove to 43.5 miles, (EVAP System Mon – OK). * Longest Distance so far w/o CEL.
*Drove to 45 CEL (P2270)
