Results 1 to 28 of 28
    Jun 19 2018
    Orange County, CA
    Need some insight/input for my stage 3 build
    Hello everyone,
    I recently purchased a '21 TTRS and am prepping it for stage 3 soon. Below are the mods that I already purchased but wasn't sure if I needed anything else. Hoping someone could chime in and see if I'm missing anything. Will I need a clutch +flywheel kit? Any insight/input will be really appreciated. Thank you!!
    -TTE700
    -Iroz LPFP (**pending purchase**)
    -Unitronic Downpipe w/ Midpipes
    -Unitronic 4" Turbo Inlet Elbow
    -Unitronic Carbon Fiber Intake System, 4"
    -Unitronic Intercooler Upgrade Kit
    -Unitronic Wastegate Line Upgrade Kit
    -Unitronic MPI Upgrade Kit
    -Unitronic 2.5TFSI EVO Spark Plug Set
    -Unitronic P3 V3 OB2 Gauge
    -Unitronic stage 3 ECU & TCU tune (**pending purchase**)
    Oct 22 2020
    Texas
    Not sure if you have an upgraded dogbone/mounts. You won’t need to mess with the tranny for a TTE700 though.
    Jan 02 2019
    Wellington, FL
    Quote Originally Posted by Auditude437 View Post
    Hello everyone,
    -TTE700
    ECE Dogbone Mount, and Motor/Trans Mounts (034 or BFI) I have had ECE dog for a while with stock mounts and they are fried (6k miles on stock mounts on stage 3), suspension? and Probably want a better wheel/tire combo to get traction with an 18" possible a 19" on a ttrs...
    Oh and definitely want a DSG catch can a must if launching at all or even 1st gear rolls with stage 3. Engine catch can is always a good thing to add as well. Charge pipes can be added as well. various companies, I have red Forge boost hose kit BNIB i'd let go for cheap if interested. Some use upgraded coil packs as well.
    If your going built motor I would definitely do flywheel upgrade from DCT or Iroz but clutches are not needed for 700. If you're planning full frame in future then yes, if not then no. Feel free to PM as well, lot of information in a private uni chat group too. I am in process of going from stage 3 stock motor to a built motor setup, and tried to do a lot of research.
    Current Stable - Built head, sleeved motor & clutches 2018 Audi TTRS Syvecs IMS 850, Litepseed Magnesium Wheels, CCB's, JJT Titanium Valved Exhaust, Stern Rear Seat Delete etc.
    Previous - Built Motor Unitronic TTE777 RS3, Stage 2 F10 M5, 16 Stage 2 Golf R, 14 C63 507 (Kleeman Supercharged, FBO), 08 CLK63 - ROW Intake/Eurocharged Tuned, 2005 MkIV VW Jetta GLI Stage2 FBO + Nitrous.
    Jun 19 2018
    Orange County, CA
    Quote Originally Posted by nothingbutspeed View Post
    Wow, really appreciate the in-depth info. I will definitely keep this in mind and will PM if I have any further questions. Thank you very much!!
    Junior Member Two Rings
    Jan 02 2020
    Florida
    Build the motor. So much more expensive to have it fail and then build.
    Jun 19 2018
    Orange County, CA
    Quote Originally Posted by MikeInFL View Post
    Yeah a lot of people have been telling me to. I'm considering it but I'm curious what the performance difference is between the stock motor tuning file and built motor tuning file.
    Jan 02 2019
    Wellington, FL
    I believe on the TTE700 its like 70ish WTQ and 30ish WHP, but yes I would strongly consider building motor too, much cheaper to do in the beginning than to repair in the end. If you go that route may want to consider tte777 too very similar spool with even more power on top.
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    Build the motor! If you go on stock block with E85, it is a disaster waiting to happen. I never launched my car, I mostly daily drove, I changed the oil frequently, and I seldom went WOT, yet I bent a rod on a low torque file after 7,500 miles and it not only cost me money, but 14 months without my car.
    If you can afford all those parts, you can afford to build the motor.
    2018 Daytona Grey Audi RS3 - Unitronic tuned ECU/TCU - TC800XT built block - STM Intercooler & Downpipe - Unitronic Intake - After 14 months, alive again!
    2015 Deep Black Pearl VW Golf R - Stage 1+ - SOLD
    2012 Shadow Blue VW GTI - K04 - SOLD
    Jan 04 2020
    azoth
    Quote Originally Posted by HWCN View Post
    Here's another example of someone with actual experience.
    I've been telling people from the very beginning that this is the right way to do it (see it on previous threads), but it's only until just recently people started echoing my sentiments.
    Better safe than sorry!
    Veteran Member Three Rings 0000 RS5's Avatar
    Jul 13 2015
    What stage? OTS tune?
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    Same specs as OP.
    Jul 13 2015
    Same specs as OP.
    Stage 3 E85 and stock block then?
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    Quote Originally Posted by 0000 RS5 View Post
    Yes.
    Jun 19 2018
    Orange County, CA
    Wow, my goodness. Sorry to hear that. I wasn't planning to drive that hard either but I think your comment alone will lead me to build the motor. Thanks for sharing that. Wow.
    Established Member Two Rings Nartard's Avatar
    Apr 09 2019
    N.KY
    Agreed on building the motor, planned event vs. a surprise event. Might also want an Ethanol Content Analyzer if it isn't part of Uni's P3 setup. And 034 Street mounts for the trans and engine.
    Jun 19 2018
    Orange County, CA
    Sorry forgot to also ask. Now that you're on a built block, are you still staying on the stock block file or are you on the built block file now?
    Sent from my SM-G998U using Audizine Forum mobile app
    Veteran Member Three Rings jd_rs3's Avatar
    Dec 18 2018
    Longmont, CO
    I don't know if there is much of a point in doing a hybrid turbo on a stock block with e85 and conservative tuning. You can't really push the engine much harder than stage 2 e85. Some people do, but as mentioned throughout this thread, it's a disaster waiting to happen.
    2018 nardo gray rs3 - sold
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    Unitronic Built block, E85, TTE 700, upgraded fuel pump file.
    The block was sleeved and the bottom end built by Iroz. They took about 12 months. Car was dissesembled, reassembled and tested by TCR. Josh at TCR was not just fast, but thorough. I can’t thank him enough for the job he did.
    I need to get upgraded motor/tranny mounts. Way too much power for the stock ones.
    Senior Member Two Rings WmRS3's Avatar
    Dec 13 2019
    Audi RS3, Audi S8, Ford Raptor, Volvo S60R
    MA
    Did the block survive or only bent a rod and scuffed a cylinder? I am stage 3 E85 stock motor but only 1000 miles on car last year. Might get that this year build is in the future plans.
    Oct 24 2017
    2022 VW Tiguan SE
    State College, PA
    Block survived. It actually ran fine and I didn’t notice it until I parked the car running and saw the blue smoke. As I stated, I never launched my car and mostly daily drove. It only made it 7,500 miles.
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    I ran Unitronic Stage3 E85 file with tte700 for around 10K miles with no issues but the stories of motor failures eventually got to me so I put a built motor in it with Iroz fuel pump and 4 bar sensors. I mostly just run 93 since I don't drag race the car and its been very reliable so far.
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Feb 02 2020
    '19 RS3, '17 Tundra, '16 3 GT, '19 Polaris Scrambler 850
    Milwaukee, WI
    Quote Originally Posted by elijahallen View Post
    Hmmm, build motor only to most NOT run E85? Color me confused? Take advantage of/Use those parts that you paid $$$ for!
    I was of the mind to eventually go to full Stage 3 Uni 710H stock block/motor E85, 93 oct for winter, but have probably decided against just hearing failures even with just DD use/driving.
    I'll probably just stick with Stage 2 E85/93 oct winter since IMO, ultimate DD is where RS3 shines. Unless I fall into a pile of money & can justify building motor...ha!
    Current: '23 GR Corolla, '19 RS3, '17 Tundra, '16 3 GT
    Past: '13 Evo X, '12 Mustang GT, '08 Civic Si, '03 Evo VIII, '01 Golf 1.8T, '84 Chevrolet Cavalier
    Nov 12 2006
    Michigan
    Quote Originally Posted by bucolic View Post
    I'm into keeping this car around for a long time and where I live pump gas file is plenty fast. Don't get me wrong, I will run E85 here and there but the TTE700 on pump gas is the ultimate daily driver and is very reliable. The built motor is just insurance.
    Feb 02 2020
    Milwaukee, WI
    How much HP do you gain going built block TTE700 93 oct vs Stage 2 E85? Doesn't seem worth it for the money you paid IMO... Maybe I'm missing something though.
    Nov 12 2006
    Michigan
    My main reason for going TTE700 was to get stage 2 E85 power on 93oct but be able to run E85 when I want to. I bought the turbo used with low miles and ran it mostly on E85 for the first year. Low 10's at 138-139. It was plenty of power for me but I worried about the motor being stock. A forum member with a freshly Iroz built motor was parting out and looking to trade his built motor plus cash for a stock one so he could trade his car in. His motor only had 3500 miles on it since the build and the compression and leak down looked perfect so I jumped on it. It cost me half what it would have cost to build mine so for me it was worth it. As for power, on pump gas it runs 10.5 at 135 which is plenty for me as a daily driver. I will put E85 in soon to feel the extra gains but it should be high 9's/low10's in low to mid 140's. For the money I have in it that is all I need and if time goes by and I want more I can just upgrade the turbo but at that point you start looking at new clutch packs and that's where it starts to really add up. If unitronic ever comes through with the flex fuel it will be a perfect no hassle daily setup that will walk nearly anything you come across, not that a stage 2 on E85 doesn't but that extra 10mph in the quarter puts it in a whole new level. Worth it? For me yes, reliability is key, power is second so I think I nailed both with this one.
    Jun 19 2018
    Orange County, CA
    If I have an Iroz LPFP and fuel line upgrade, will I be able to safely run E85 all the time without any issues? How about over time? The car is a weekend car and it'll stay in the garage a majority of the time. I'm concerned what it will do when the E is just sitting in my gas tank. I'm in socal so there's plenty of E85 fuel pumps around here but was concerned since I value longevity/reliability as well and there's only 91 pump gas around here. There aren't many performance numbers for stage 3 TTE700 on 91 pump gas either.
    Nov 12 2006
    Michigan
    If I were you I would run the tte700 on pump and splash 3 gallons of e85 in it. Its safe, its faster than stage 2 E85 and the motor and drivetrain will last a long time as a daily.
    Jun 19 2018
    Orange County, CA
    Sounds good, will keep this in mind. Thank you!
