Results 1 to 20 of 20
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    B9 Q5/SQ5 ROW amber tail light conversion for US
    UPDATED WITH VIDEOS, PICTURES, AND DETAILED COST ESTIMATES
    I finally swapped my North American (NA) 2018 SQ5 tail lights with a second hand rest of world (ROW) pair I sourced via eBay Germany. The following process should work on NA 2018-2020 Q5 and SQ5 models.
    My motivation was to get the amber turn signals and to decouple the brake lights from the turn signals.
    Costs
    • Actual cost without selling original tail lights: $930 USD
    • Estimated cost including sale of original tail lights: ~$470
    • Estimated cost including sale of original tail lights + VCP tool: ~$220
    My DIY approach with second hand tail light units sourced from Germany at ~$580 USD + the Vag Con Professional (VCP) programming tool at $350 cost around $930 USD.
    Assuming that I can sell my original NA tail light units for $460 for the pair (UPDATE: I actually sold each original tail light for $230 USD + shipping via eBay), the net outlay in parts cost will be ~$470.
    If I can transfer ownership of the VCP unit and sell it for, let's say ~$250, then I'm looking at a net cost for this upgrade to be ~$220.
    If you’re not keen on rolling the dice by purchasing second hand ROW OEM Q5/SQ5 tail lights, I recommend that you contact Alex at Europrice to source new ROW OEM lights, coding instructions and a VCP unit if you don’t have one. I believe he offers the VCP tool at a discount when you also source a set of new OEM ROW tail lights through him.
    ROW Tail Light Units
    ROW tail light part numbers:
    80A945093B
    80A945094B
    The second hand pair I purchased on eBay Germany cost about $580 USD including shipping and took about two weeks to get to me. They are in excellent cosmetic condition. (More on the actual amber LED performance below).
    (The NA tail lights are the same part numbers, but with an “A” in place of the trailing “B”).
    Male Connectors
    The position of the wires in the connectors appears to be the same for NA and ROW tail lights, but the connectors are not compatible. Note in the following picture that the tab on the left side of the tan NA male connector does not line up with the slot on the left of the ROW female connector:
    Fortunately, you have several options ranging from simple to more complicated depending on your interests:
    1/ Remove the incompatible tab from the NA male connectors: Use a utility knife to remove one thin blade from the each of the NA male connectors so that the connectors will fit into the ROW female connectors in the ROW tail lights. The slightly modified male connectors still snap into place. When you compare the NA male and ROW female connectors, it should be obvious as to the thin blade that you can shave off.
    Since I got tired of waiting for the ROW male connectors that I ordered (see next option), I started with this approach.
    Here's a result of using a utility knife to shave off the offending tab:
    2/ Order compatible male connectors and replace the NA male connectors: The part number is 8W0971636B. You’ll need two. They might cost anywhere from $8-$14 depending where your source them. It’s a part that’s generally available in the US.
    You'll need the proper tools to swap the connectors.
    As I mentioned above, I ordered these connectors but I probably won’t bother using them because option 1 was so simple and still results in a solid connection.
    3/ Make a short adapter harness: You could source the female connector for the NA tail light, the ROW male connectors, and some proper wire to make your own plug and play harness.
    Coding
    Without doing any coding, the ROW lights functioned just like the NA units except for the amber vs red turn signals. The brake light will illuminate along with the turn signal.
    I was hoping that, like the B8s, I could simply use my VCDS unit to make some programming changes to avoid turning on the brake lights when the turn signals are active. That’s not the case. After a lot of researching and consulting with Alex of Europrice, it became clear to me that you need to use a tool like VCP in order to send the right parameters to the module that controls the tail lights. Apparently, VCDS can not yet send parameters to modules.
    This was a $350 “investment” that I was hoping to avoid. But Alex was great in that he had VCP units in stock and got one to me in two days.
    OK, so the final step was the actual coding.
    Use the VCP Activator to download necessary ".zdc" file
    Using the VCP Activator program, you can download .zdc files that contain predefined codes and parameters for different modules. After some trial and error, I found that the file BCM2_q5_4n0907064am.zdc contained the necessary magic to separate the brake lights and turn signals.
    1. Start Activator
    2. Connect your dongle. Ensure that you have an active VCP subscription.
    3. Select Filemanagement
    4. In the text entry box, paste "BCM2_q5_4n0907064am.zdc"
    5. Select "Download selected"
    Use the VCP System program to upload the settings
    1. Start VCP System program
    2. Select "Guided Functions"
    3. Select "Apps" on the lower right
    4. Select "Upload parameter data" and "Next"
    5. Select "Next" several times
    6. Select "Open ZDC file"
    7. Select the .zdc file you downloaded earlier
    8. Under "ECUs", enter "46" in the text box to select "Central Module Comfort System"
    9. Under "Data to upload" select the 7 files of the form "DATA_720x_LAMPCONFIG_EU_CONFIG" where “x” has values 0, 2, 3, 4, 5, A, and D.
    10. Select "Upload selected data"
    After the data has been uploaded, the turn signals should operate independently from the brake lights.
    Here's the result of the datasets having been applied to the module:
    BTW, even without swapping your NA tail lights for ROW, if you have access to VCP, you should be able to perform this separation with your red turn signals.
    Results
    So, am I satisfied with the result? Sort of. I’m happy to have turned off the brake lights when the turn signals are active and to have more visible amber rear turn signals.
    I’m not as satisfied by what appears to be the design of our progressive rear turn signals in general.
    A few years ago, I did a similar swap on my MK7 Golf R. In that case, the OEM euro amber tail lights have a modern light tube effect in which you can’t see the individual LEDs.
    With the Q5 tail lights I purchased, I can clearly see each LED when the turn signals are active. I.e, in person, there’s not much of a light tube effect. To me, it’s more of a 2012ish look as compared to the rear red running lights and their very modern light tube effect. Here's a picture of how you can see the individual LEDs:
    I swapped back my NA tails to compare and found the same result: the individual red LEDs are also visible when active.
    The funny thing is that when you take a video of the lights in action, you get a progressive light tube effect. Consequently, my thinking is that this is just how the 2017 (2018 NA) - 2020 tail lights are designed. See the videos linked to at the start of the post for examples of how the turn signals have the light tube effect when recorded via video.
    It would be helpful for any ROW B9 Q5/SQ5 owners to confirm that they can see the individual amber turn signal LEDs rather than a progressive light tube effect. That at least would help confirm that I didn’t get a defective or older pair of ROW tail lights. (Although I’m not aware of any variations in the ROW B9 2017-2020 tail lights).
    Last edited by ckamps; 09-05-2022 at 07:00 AM. Reason: Added videos, photos, and detailed costs
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Quote Originally Posted by ckamps View Post
    I’m thinking about buying a pair of rest of world tail lights for my US-based 2018 SQ5 in order to get the progressive amber turn signals.
    Does the coding and potential pin swapping that has been used in this context for B8 Q5s also work for the B9?
    I believe if that Europrice includes the necessary hardware and coding information to make this work on US B9s. Reach out to Alex there he'll definitely give you the straight skinny.
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    Thanks for the response. I failed to mention that I’m leaning toward buying a pair of used tail lights. Should be < $600 based on what I’ve found this far.
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    Bump. I rewrote the first post to reflect the results of swapping my NA B9 SQ5 tail lights with ROW units.
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    Bump. Added videos, photos, and cost estimates.
    Sep 07 2018
    Colorado
    Nice. Great write-up
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Yea, nice write-up. Thanks for sharing.
    iain
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    UPDATE: It took a few months, but I sold each of the original tail lights for $230 USD + shipping ($460 total + shipping for the pair) via eBay. I’ve updated the costs in the first post accordingly.
    Sep 07 2021
    Virginia Beach/VA
    Hi All, I decided to follow the "ckamp", I ordered rear lamps (ROW) in Europe, it came. Their mechanical replacement took two hours. The challenge is to remove the tailgate cover ... The plugs fixed in two movements with a pocket knife. Now I have lamps (turning signals) with amber color indicators. There remains the coding (separation) of the brake lights from turning, what means they would stop blinking when the direction indicator flashes, the rest works as should position lights - running and braking work as they should. I haven't bought a VCP yet but I wonder if it can be done with OBDeleven sec. generation ... will let you know.
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    Quote Originally Posted by Johny Koval View Post
    Hi Johny,
    I’d be willing to sell my VCP for a lot less than new if you can validate that it can be transferred to another owner. PM me if you’d be interested.
    Did you source new ROW tail lamps or buy second hand?
    Have you also noticed that the amber turn signals are not uniform when they light up? I.e. that you can see the individual LEDs faintly when turn signals sweep?
    Sep 07 2021
    Virginia Beach/VA
    Hello, I was a bit busy, I bought second-hand, but they are in perfect condition, they look like new, and the price was a really occasional low . Well, single diodes are visible but only when you look at the lamps from short distance, very closely :). I think I'll be interested in buying VCP, but I have to see if I can do it with OBDeleven 2.
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    Good to know on being able to see some of the LED diodes. Leads me to believe that this is just the way they are. Thanks for the follow-up.
    Current 18 B9 SQ5 | 16 B8.5 Q5 3.0T
    Past: 18 B9 A5 Sportback | 17 MK7 Golf R Manual | 16 MK7 GTI DSG | 12 B8 Q5 2.0T (oil burner) | 12 B8 S4 3.0T Manual | 03 B6 S4 4.0 V8 Manual (vroom!) | 97 A4 3.0 Quattro Manual | 93 Corrado VR6 Manual | 75 VW Rabbit
    Apr 27 2011
    Romania
    Great write-up, thanks for sharing!
    I have changed the tail lights on my Q5 FY 2018 from normal EU ones to the ones with the dynamic blinkers EU : 80A945093B and 80A945094B, just plug & play by chopping with the knife the connectors. I changed the BCM2 for the keyless retrofit and dynamic tail blinkers .
    I have tried to upload the BCM2_q5_4n0907064am.zdc file with VCP but I got an error:" Incorrect message length-wrong format" and other Q5 files I could not find, nevertheless I raised a ticket to VCP support.
    In the mean time is there another possibility to adapt the channels directly via VCDS, or someone can share the adaptations value for the EU Taillights?
    Many thanks for any ideas!
    Sep 07 2021
    Virginia Beach/VA
    Quote Originally Posted by mgbyte View Post
    Hi, I still haven't found a coding solution other than the one described above by ckamps on the VCP, but since I haven't bought VCP yet ... I'm still flashing orange and red together on a turn and red when pushed brake. I did not find a description/solution of how to do this on VCDS (supposedly impossible ...) or on Obdeleven - but people here write that it is possible. I also visited the Audi service in Virginia Beach, where I was first told that there was no problem and they would re-coding my lights if I installed the original EU lamps and then found that their software has this function blocked for safety reasons (there are no official EU lamps on the US market) .
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    FWIW, since I had to reapply the configuration changes after having had my SQ5 serviced, I updated the instructions in the original post with step-by-step VCP coding instructions. Those steps worked for me today.
    Established Member Two Rings sweet2bad's Avatar
    Mar 16 2016
    67 Mustang FB; Aprilla RSV4R (trackbike); Suzuki GSX-R1000
    Mississauga/ ontario/ Canada
    Excellent write up!
    Hoping you can offer some more info.
    I've been contemplating doing the tail light swap (North American for row) for about 7 years lol (since i had my last Audi)
    I'm finally going to try and source them (for my 2019 sq5) from Europe.....
    but in the interim i may try what you mentioned above.
    Do you know for sure (out have you heard from anyone else) If i have vcp, and use the same zip file you mentioned, on my ORIGINAL 2019 tail lights - it will/should separate the sweeping signal or from the brake light that normally comes on when you signal?
    Lmk!
    Feb 26 2023
    Poland
    Hi can you post .zdc file BCM2_q5_4n0907064am.zdc ?
    Stage 2 Banner Advertiser Four Rings Miranda@Nemesis's Avatar
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    I just did the same mod, but with the 9.5 OLED tails. One of my favorite features.
    Miranda@NemesisAutosport.com
    Nemesis Flickr | C43 Build | IG
    Oct 30 2006
    2011 GT3 RS, 2011 C63AMG, 2012 E63 Wagon, 2010 ML550, 2006 A3 commuter
    ca
    Has anyone tested the VCP coding on standard US tails?
    Established Member Two Rings Franky_d's Avatar
    Oct 18 2012
    Scandinavia
    Post
    Hi!
    Thank you for the excellent write up and all details/pictures!
    I've successfully used original VCP and "BCM2_q5_4n0907064am.zdc" on BCM2 with SW nr 4n0907064cp, HW nr 4n0907064p.
    Cheers!
