The pinch weld on this car is super small. They give you a small section to put your jack and jack stands on, and the rest is covered with plastic. The fit is very tight and sometimes I have to lower the car and jack up a 2nd time to get it aligned properly, even then the jack stand has to be tipped ever so slightly, let the car down on the jack, then it settles flat.
Not what I want to be doing so is this the only method or what is the best way to jack up the car and place on jack stands?
