Results 1 to 15 of 15
    Nov 26 2017
    Hungary
    3.0 V6 5 and 6speed ratios
    Hello Guys,
    Could you tell me, why Audi brought the B6 model into US with 5 speed manual and 6 speed manual to Europe? Has anybody any info about the gear ratios to compare them? I've checked the automobile catalogue, which is highly detailed, but there is no info about the gears for 5 speed, only 6 speed.
    Hope you can help me.
    Thanks in advance.
    Cheers.
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    I have a 2003 3.0, built in 2002. It has a 6-speed manual transmission.
    I've never heard of a (factory-installed) 5-speed manual in a B6 3.0.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    To add to that... The 1.8t in the US started with the five speed and went to the 02X six speed in 2004. The 3.0 started with the 01E six speed in 2002 and also went to the 02X in 2004.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    I'm pretty sure that all 3.0 cars had six gears, manual or auto, unless you got a CVT.
    Sent from my Pixel 5
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Didnt think the 3.0 ever got the 5spd, even across the pond.
    Here is a good source for all the different gear boxes that were used throughout the years/motors.
    https://www.audizine.com/forum/showt...ht=gear+ratios
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Jan 24 2010
    Paramus,NJ USA
    All 3.0 AVK's with manual transmissions were a 6 speed manual. 2002-2003 had a 01E with grear ratios very close if not identical to the original rs2 cars from europe. 01E transmission is stout AF, one from a 3.0 is better suited when mated behind a 1.8T or other small displacement engine swaps.
    Ziddy Autowerks
    Mar 28 2015
    Some Ratios:
    Mar 28 2015
    1.8T 5 Speed, B6
    Final Drive 3.89
    1 3.778
    2 2.176
    3 1.429
    4 1.091
    5 0.889
    B6 01E
    4.11 final drive
    1 3.5
    2 1.889
    3 1.32
    4 1.034
    5 0.857
    6 0.73
    Mar 05 2013
    CA
    Quote Originally Posted by phareck View Post
    they didn't
    look at the repair manual
    Nov 26 2017
    Hungary
    Well, I've checked the VIN number and the MyAudi showed this:
    WAUZZZ8E42A083640
    This is not my car, I thinnking to buy it.
    Senior Member Four Rings Deerhurst's Avatar
    Jul 22 2019
    1986.5 SE-V6 4x4 Nissan D21
    Oregon
    My quick search shows that is not a US VIN. I think most.of us are from the US and more familiar with the US options.
    I know my 03 3.0AVK has a 6 speed O1E.
    2003 A4 Avant 3.0 6MT Quattro
    2003 A4 Avant 3.0 6MT Tuned, TTV SMF, RS4 Clutch, Joey Mod, Clear Corners, Mini H1 7.0, Xtrons, Skar Audio, Panda Subs
    1986.5 SE-V6 4x4 D21 Cammed, Long Tubes, VG33 swapped
    Nov 26 2017
    Hungary
    This car has a 5 speed manual. This is how it came out from the factory. Now it's a fact. All I want is to compare the gear ratios with the 6speed gears.
    Feb 27 2011
    Winnipeg
    in my searching of car-part when I was looking for a used 01E it listed a manual trans for 02 B6 3.0 for north america, probably very early vin and low production cars. Just checked and the code car-part gives is FJV
    Jun 05 2013
    Ottawa
    Out of all the B6s 3.0s I have seen, and I have seen a lot from multiple junk yards(I have 4 in my garage), local part outs, online here on audizine, audiworld, ebay, audisport, audi world, technical data from bently, audiworkshop manuals, dealer part listings, etc. I have never seen a 3.0 listed with a 5 spd from the factory. What "website" are you using that is "decoding" the vin, I could not locate a MyAudi vin decoder.
    That being said, the only way to tell is to check for the gear box code:
    I wouldnt trust the PR codes found in the spare wheel well/under the seat or in the owners manual because think it was swapped to a 5 spd. Its pretty cheap and easy to swap a gear box and rear diff to 5spd equipment these days. Once you know what transmission you have, then we can compare final drive ratios, otherwise we're just crap shooting.
    2007 RS4 Avant
    Aug 12 2009
    Dirty Jerz
    The OP is in Hungary based on their profile, and I'd guess the car is in Europe based on the listing he posted. The car could have come from the factory with a 5 spd. OP, if you can get the transmission code, we can probably figure out the gear ratios.
