Results 1 to 12 of 12
    Junior Member One Ring DeCaptain's Avatar
    Jun 08 2020
    Do I have AFS headlights?
    I have a 2013 Q5 3.0T with the S-Line package. Wanted to confirm if it has the AFS headlights or not.
    These are the part numbers i found on top of each headlight:
    Left: 8R0 941 005 B (Valeo 90021778)
    Right: 8R0 941 006 B (Valeo 90021779)
    The headlights dip down then come back up when I start the car, but I don't notice them pointing left or right while driving/turning.
    Trying to replace these because they were pretty hazy and a headlight restore didn't help much. The haze seems to be inside the clear housing...
    Veteran Member Three Rings tbaudi's Avatar
    Jun 21 2011
    Naperville, IL
    I believe that AFS is not the lights pointing when you turn, but rather an additional bulb that is pointing diagonally out the housing that is illuminated when turning.
    Sent from my SM-F707U1 using Tapatalk
    '16 Q5 | Prestige, S-Line, Sport, Black Optics | silver/black | EPL stage 2 SP | BG TCU tune (HPT) | B16 PSS10 (C7 version) | BBS CH-R staggered | RS Grille | 034 RSB w/ TRW end links | Airbox mod | RSNAV Standalone Planned - Custom exhaust tips
    '05 S4 Cabriolet | RS4 wheels
    Gone but not forgotten - '11 A4 Avant | Prestige, S-Line, Sport | silver/black | BG TCU tune (HPT) | RS grille | RSNAV Standalone | Black finished wheels | 18/35 SunTek Carbon tint
    Jun 08 2020
    Ahh okay I think I see it now. Then i do not have AFS lol
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Quote Originally Posted by tbaudi View Post
    Somewhat correct answer
    MY 2009-2012 exists with AFS. On MY 2013-2017 it is called a headlight for cornering light and they have an additional bulb
    You have a spare parts diagram attached, so you can see for yourself
    Audi Q5 2009-2012
    Audi Q5 2013-2017
    Oct 10 2010
    Sarajevo, BiH
    Quote Originally Posted by DeCaptain View Post
    You have standard front headlights
    S-N: 8R0941005B replaced with 8R0941043B
    8R0941043B replaced with 8R0941043E
    Jun 08 2020
    Thank you @spijun!
    Oct 29 2005
    10speed
    San Francisco, CA
    if you have heated and cooled cupholders, then you have AFS lights.
    - Clint
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The standard headlights have "Static Cornering" lights, that light up at slow speeds when turning. These are the halogen H7 bulbs at the outer portion of the headlight housings.
    The Prestige trim level has the Static Cornering bulbs AND active AFS, which aims the HID projector units left or right, depending on the steering wheel angle, at higher roads speeds (higher than when the Static Cornering lights are active).
    Oct 10 2010
    Sarajevo, BiH
    Quote Originally Posted by S4'ed View Post
    That is simply not true
    Pictures speak more than 1000 words
    Standard headlights do not have an additional H7 bulb
    Jul 31 2016
    PA
    Agree with above, I have standard bixenon and they do not have the cornering lights. Only thing I could possibly do code the fog as a cornering light in VCDS.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Sep 24 2014
    Central NJ
    Red face
    I stand corrected....I was thinking about my VW CC which had static cornering lights standard, and AFS swivel lights with the Xenon HIDs of the higher trim levels.
    Feb 12 2008
    Michigan
    I have afs and have a light system failure, scan says left bulb open circuit. It was blown i replaced it.
    Car still says i have a fault, scan no longer pics it up.
    Not sure how to investigate it further. Everything online has just been fixed by replacing the h7 bulb
