So i finally made up my mind on which wheels I want, which finish I want, and I come to find a thread of a few people saying the barrel of the Rse11R is too tight around the front caliper will rub with heat expansion tracking the car.
Some caveats:
There is some confusion as the wheel was redesigned from Rse11 to Rse11R and one of the changes was opening the wheel barrel more to fix this issue. I'm wondering if those experiencing the issue were mistakenly using old stock Rse11.
Those reporting the issue were all using aftermarket rotors (372mm) albeit only 2mm of difference, 2mm can be all you need, but I wouldn't like knowing I cant upgrade my rotors.
So what i'd hope is that members who drive with RSe11R 18x9 et45 (and I know there are a lot of you out there) with either stock brakes or upgraded brakes chime in and tell me if you ever experienced the issue.
