My car started to burn more fuel (about 20% reduction across board), used to get ~28mpg on highway at 75mph, now about 24mpg.
I had several issues, but short version is I have new PCV, new turbo, new O2 sensors, new cat, new MAF. These restored power (had a loose wastegate), but now I am getting P0420. Fuel usage did not improve. I pressure tested intake and found a small leak that on a clamp that didn't appear until 25psi. It didn't do anything to resolve as it is stock so I don't think it even hits this high of a boost. Vacuum at idle is 3in Hg at dipstick as expected. I see no exhaust leaks at manifold, turbo to cat, or cat to exhaust.
My short and long term fuel trims are decent at idle and under use (less than 10% always). I'm at a loss to figure out the problem.
Before I changed the cat, car would have a pretty strong unburnt fuel smell at startup that is not there now. There is no abnormal smell of gas in oil. But I checked the fuel rail pressure actual vs specified, and while its all good... I am under the impression that when engine is hot, and you turn off ignition you should see increase in actual pressure. This does not happen. It pretty much stays where it was when running. 4000Mpa, dropping just a teeny amount over a few minutes to like 3970Mpa. But it doesn't increase due to heat soak. Does this tell me anything? Is it indicative of a fuel injector not totally closing?
Either my new cat is bad and the mpg reduction is due to something else, or its running rich and for some reason the MAF and precat o2 sensor is not adjusting fuel trims. Other thoughts?
How do you test the injectors?
