Results 1 to 6 of 6
    Apr 08 2008
    Columbus, OH
    Headlight options 2014 allroad
    Needing a new driver headlight for the ladies prestige allroad. Had the upgraded lights with the active cornering. Do prestige bbe. A4/s4 lights work? On the pic n pull sights allroads are like 800 to 1k
    Sent from my SM-G998U using Tapatalk
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Yup A4/S4 headlight will work just fine! They are no different
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    May 10 2015
    Pittsburgh PA
    Just make sure you get another AFS headlight. The AFS lights have a small cornering bulb the standard lights lack, that's probably the easiest way of identifying them.
    I bought (on accident) a used AFS light on ebay for $200 a couple years ago, don't be afraid of a couple broken tabs. As long as there are enough mounting points to be secure the light will be fine and you'll save some money!
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by japanada View Post
    As said above, look for A4/S4 headlight with AFS. I believe the option code is 8Q3. Someone, please verify.
    As an aside, if you are at a pick pull with an Allroad, please let me know. I am looking for an undamaged driver side upper bumper cover. Thanks!
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Dec 04 2019
    West Chester, PA
    I'd suggest looking on ebay.co.uk. You can get some e-code lights for about $180 USD.
    2007 Toyota corolla
    Jul 16 2018
    Atlanta
    For PR codes, there are two of relevance.
    One is for the beam tech and pattern: 8BD is ECE spec halogen, 8BJ is US spec halogen, 8BP is ECE spec HID, 8EH is US spec HID.
    One is for the adjustment tech. 8K has: 8Q0 is no leveling, 8Q1 is manual leveling, 8Q3 is auto-leveling, 8Q5 is auto-leveling with cornering.
    B8.5 US spec HID+AFS (8EH+8Q5) is going to be 8K0 941 753 E left, 8K0 941 754 E right. This will be the same for A4 or S4, sedan or avant or allroad.
