The kit includes the boot itself, hose clips, circlip, bolt, and 120g of G 052 528 A2 CV joint grease - everything you need for the repair:
However, what I struggle to understand is the exact amount of grease to be used for my drive shaft and its distribution between the CV joint and the boot.
The VW/Audi service manual has the following table:
The table shows different variations of the outer CV joint based on diameter. I have the 8K0 407 271 AL drive shaft, which appears to correspond to the 85/88mm one from the table.
My two questions are:
1. What are these 85 and 88mm numbers? What dimensions they represent? I guess these are CV joint outer diameter, but in what exactly places would I measure these?
2. Why there are two numbers in the second column - Grease Total quantity? In my case these are 128/90g. So how much grease my 85/88mm CV joint require after all: 128 or 90g?
I would appreciate any insight on this.
I do realize that I can just go ahead and put 60g from the grease pack supplied in the kit to the CV joint and the remaining 60g to the boot and be done with it. But I'm curious to find out how to read that table from the service manual.
