Results 1 to 19 of 19
    Junior Member One Ring
    Mar 22 2021
    San Mateo, CA
    Stock tire pressure really 49 PSI? And is it normal for one tire to run hotter?
    Hi all,
    Had to put some air in all the tires yesterday. Car shows that it should inflate to 49 PSI on cold tires. Pardon my ignorance, but wouldn't that mean higher than 49PSI when the tires warm up? The tires list a 50PSI maximum pressure on the sidewall.
    Also, in the car monitor yesterday, I saw that one tire (the front left) was running almost 10 degrees hotter than the other tires. Seemed odd but still showed as green.
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Stock tire pressure is not 49 psi. What is on the door jam is the max tire pressure and not the recommended tire pressure. Always go by the manual.
    For everyday driving, I run 40 front and 38 rear, then adjust if needed but can’t say I’ve yet gone above 155 mph to warrant so.
    Mar 22 2021
    San Mateo, CA
    thank you!!!
    May 16 2007
    Ottawa CA / DE USA
    Quote Originally Posted by shiftypowers View Post
    thank you!!!
    no problem
    Senior Member Three Rings gpoulos's Avatar
    Sep 23 2019
    So for ceramic brake rated 190 mph. It is indeed 49/44?
    2021 RS6 Avant Nardo Black/Red
    Oct 10 2019
    Toronto, Ontario
    Quote Originally Posted by gpoulos View Post
    But that's only if you're planning to go up to 190 MPH.
    If not, the recommended tire pressure is lower.
    I'm going 45/42 at the moment.
    I notice the TPMS is all over the place. It jumps up and down by 1.5 PSI when my other cars have always been pretty stable and within 0.5 PSI. Anyone else notice this as well?
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    Looks like it. Mine 21" winters were set at 35 all around then I changed them shortly after to 42/39. The 22" summers going on tomorrow will be set at 45/42.
    Junior Member Two Rings
    Feb 28 2021
    Quote Originally Posted by KJ-RS View Post
    Yes, I have. The TPMS readings seem quite useless. I'm finding that even after setting L/R tires to the same pressure using a precision gauge (to 0.1 psi), the TPMS will read as much as a 3.0 psi difference between the two tires. I guess it's only going to be of help when a tire really is losing pressure.
    ________________________________
    2021 RS 6 Avant Daytona over Cognac
    Mar 05 2020
    Chicago Metro
    Quote Originally Posted by sdlos View Post
    I thought it was just my fat ass resulting in a higher tpms reading often on the driver front hahaha.
    Sep 23 2019
    I’ll drop to 45/42 tonight. Not going over 175
    Mar 22 2021
    San Mateo, CA
    Thanks for all the responses around this. The PSI is indeed all over the place. Going to confirm this weekend with a more accurate gauge. What about the temps. Is that just a nothing burger or do others see this kind of variance in one wheel?
    Apr 13 2012
    San Diego
    My gauge that is good to .1 has mine all set correctly but the tpms are crap. They only read in 1.5psi blocks but I can attest to them working on a rapid deflation so at least there’s that. Kinda sad their flagship cars got such outdated tech in something like this. I mean a cheap car now days has accurate tpms. It’s the little things with this car that just baffle me sometimes.
    2021 RS6 Avant - Navarra Blue with Xpel Stealth, Vossen S17-06 in Dark smoke, lowered 25mm, Milltek exhaust
    Mar 22 2021
    San Mateo, CA
    what about the temperatures? are they all the same for you?
    Mar 05 2020
    Chicago Metro
    Fronts run warmer than the rears for me but that seems to make sense.
    Apr 13 2012
    San Diego
    varies on how I drive as well :)
    Sep 23 2019
    Odd thing happened. Lowered the pressure. Tpms measures 45/42 and I’m thinking great! I go in and store the new pressure in the mmi. Now it won’t read any pressures. Slightly confused why.
    Oct 20 2020
    Same thing for me. Had the winter OEM wheels taken off and the OEM summer wheels put on and now the tire pressure won't read. Tried storing pressures, but no luck. I hope its an easy fix.
    Mar 05 2020
    Chicago Metro
    I got my summers swapped on today. OEM. No problems storing nor with readouts. I think I remember seeing somewhere it can take a little while for the sensors to display values sometimes after changing them.
    Sep 23 2019
    It started measuring again this morning
