Results 1 to 22 of 22
    Senior Member Two Rings Spetznaaz's Avatar
    May 26 2019
    U.K, South Wales
    Car Batteries - Which ones do our cars need?
    So after playing music while vacuuming my car for 10 minutes, the battery went completely flat. Tried push jumping it but that didn't work so ended up calling breakdown who determined it was dead and jumped my car with cables. Despite what he said after driving around for a bit it is holding enough charge to start the car but i definitely need a new one.
    I've tried looking online but there doesn't seem to be much info and when i put my reg into sites i get multiple batteries come up with different dimensions all of which are significantly smaller than my current battery. Is there any sort of specs the battery must be to be compatible or is it simply needing enough cold starting amps and to fit?
    This is what i currently have in there, a Yuasa YBX3110 - https://www.tayna.co.uk/car-batterie...IaAsLtEALw_wcB
    It's very big and heavy though, so something smaller would be better if it's okay.
    Edit - Also, he told me removing the jumper cables while my engine was running ran the risk of frying the ECU, due to a voltage spike caused by the alternator suddenly detecting a low battery and trying to compensate. I couldn't find any info of this online so i'm curious if anyone knows if this is true?
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    I read once that AGM group 35 will fit, got one and indeed it fits. (yes its fixed with the bracket, battery dont move)
    It saved me about 17 lbs, not much , but better than nothing !
    the frying part doubt its true, if so, almost dead battery would be a problem. BMW got fancy stuff that calculate capacity to avoid burning the alternator on a dead battery, it needs to be adapted on each battery change, and you need to code the ecu in case you change the batt capacity over OEM. But nothing about this on the B7.
    May 26 2019
    U.K, South Wales
    I couldn't get my head around the sizing. I've seen groups mentioned many times but all the batteries i find here seem to just have a three digit code, not all of them though - Perhaps the U.K uses a different system. I've also noticed people saying different groups fit, 28, 29 etc not sure if i'm being stupid but it's very frustrating lol
    It's been a while since i took the battery out and i've forgotten but is there a bracket that will hold any sized battery in place as long as it isn't too big?
    Jul 01 2015
    Mtl
    width is what you need. Length is not that important, bracket is on the bottom face of the battery
    My old fat battery was 6.75'' width, and the AGM is 6.5''.
    I went to the store with my measurement tape.
    Having a smaller size battery means that I need to put the tender more often to make sure its full charge not to fry the alternator. Running the navi, heating seats, meth kit, after market subwoofer+amp, bose system, hid, fog, hvac, etc ; never had any issue in 1 year so far.
    cranking amp get from 790A to 755A, not a huge deal.
    Since this platform was designed, battery evolved a bit. Go with the battery width and the cranking A at the store, and you should be fine.
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    Simple answer H7 in you want beefy battery. H6 if you just want to start your car
    Here is the Audi part number if you wish to buy genuine. It's just 145$ at the dealership
    000915105DH
    May 15 2019
    Bellevue, WA
    Simple answer- H7 in you want beefy battery. H6 if you just want to start your car and do your regular chores.
    Here is the Audi part number if you wish to buy genuine. It's just 145$ at the dealership. I am using this one with 2 dash cams running 1080p 24/7.
    000915105DH
    Sent from my iPhone using Audizine[/QUOTE]
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    i thought h8 was the factory size? when i changed mine about a year ago i believe i pulled out an h7 and replaced with h8 agm.
    This one and since i carried my old one in, the core refund was instantly applied.
    my last battery came in the car, not sure when it was installed, worked perfectly fine for 4 years, only died cause it sat for about a year.
    Senior Member Two Rings HerNameIsBeast's Avatar
    Jun 11 2020
    Detroit
    I installed DieHard Gold H8 last August and have been nothing but happy. Michigan winter was no issue for it. The fit was perfect as well.
    Sent from my Pixel 4 using Audizine mobile app
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    H7 is the factory size, but h8 fit nice if you remove the little bumper on the end. H8 is only like 3/8" longer, same width, and usually little more CCA. But for some reason, the h7 batteries were about $50-$75 more than same one in H8. So I went with an H8, was about $140 at Advanced Auto for H8 AGM. And no need to worry bout coding, or anything special till b8's.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Mar 26 2015
    I’ve always had H7s in the 7 years I owned it and have always had issues with low voltage even after replacing the battery multiple times.
    I now have an H8 and have not had any issues.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Dealer is best bet! My second 'Genuine Audi Parts' battery. Can't beat it for $175.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    May 15 2019
    Bellevue, WA
    Quote Originally Posted by 80sGuy View Post
    Do you know how long they warranty the batteries at the dealership? I bought the same one last year never bothered to ask about warranty though!
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Outside of going through Yellow Tops, and Red Tops, I run Duracell.
    Old Red Top
    https://www.samsclub.com/p/duracell-...=plp_product_3
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Jun 27 2011
    I'm quite pleased with my Bosch S6 AGM Group 49. It has 850CCA, p/n S6588B.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 09 2007
    Miele S7
    Quote Originally Posted by Jeevan View Post
    I remember them quoting me something like 24 month/unlimited mileage, whichever is greater; then the battery is prorated for parts only up to 60 months. I'll update as soon as I find my paperwork
    Aug 18 2020
    Sonoma, CA
    I used a Costco (Interstate) AGM H7 for my kids A4 Quattro.
    Aug 18 2020
    Sonoma, CA
    It is a hassle if you don't have the means to do this yourself.
    May 15 2019
    Bellevue, WA
    Car Batteries - Which one do our cars need?
    Not just BMW, Audi's from B8 have that crap too. You have to recode the new battery to avoid it from burning in couple days. Alternator tends to over charge the new battery thinking that it's an old dying one.
    https://youtu.be/cISB8N4sgqg
    Jun 27 2011
    I don’t even want to think about what sort of nonsense my Q7 will need when I have to replace the battery.
    -CP
    2017 Q7 3.0t
    Mar 04 2019
    Staten Island, NY
    I put in an H8. 900 CCA. purchased at Walmart. Good price and better warranty than any other. Only a few battery manufacturers so not too much difference between brands.
    You a bounty hunter...Man's got to do something for a living these days......Dying aint much of a livin boy....
    May 26 2019
    U.K, South Wales
    Thanks for the replies guys. Battery terminology confuses the hell out of me - I can't find any batteries here with a H number attached.
    I have however managed to find out that a "type 96" battery will fit.. not sure if that's a different way of saying group or what but apparently they will fit.
    Sadly, i'm poor as hell right now else i would just get one straight from Audi (or a nice lightweight Lithium Ion one). I would get the Bosch S6 as recommended but it's a bit pricey, does anyone know if the Bosch S5 would be suitable, it's "type 96" so should but want to check before i make the purchase.: https://www.tayna.co.uk/car-batterie...0aAnpREALw_wcB
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Warranty on these is 1 year (according to our dealer). I had one go on my B7 after 13 months.
    I had a failed battery on the S3 after 10k miles, then again after 4k, battery on the Q5 went after 8 months... both cars brand new (batteries covered under warranty).
    Never ever had an issue with a diehard.
