Anyone have experience with these 2 brands? Not many good options available locally here in Kanada... was just quoted over $600 parts, labor and tax by dealer!
costco kirland approx $150 but it's flooded
Group Size: H7
Item #270545
Battery Specifications:
Cold Cranking Amps 790
Cranking Amps 985
Reserve Capacity 130
Amp Hours 80
Voltage 12V
Dimensions: (millimetres)
Length: 315
Width: 175
Height: 190
agm H8 energizer is approx $280
Specifications:
Dimensions (L x W x H): 35.3 cm x 17.5 cm x 19.0 cm (13.94 in. x 6.94 in. x 7.50 in.)
Weight: 26.60 kg (58.70 lb.)
Specifications
Amp Hour: 95
Battery Type: Absorbed Glass Mat (AGM)
Cold Cranking Amps: 900 Amps
Cranking Amps: 1,000 Amps
Reserve Capacity: 160 Minute
Voltage: 12 Volt
Is the stock dealer battery at $300... is it much better? Also, is the stock battery an H9?
I will spluge if necessary but never want to feel I'm being gouged...
