Results 1 to 18 of 18
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    Front Strut Removal On S3
    I'm planning on replacing the strut mount and bearing assembly this weekend on the front passenger side in the hopes it resolves the grumbling / moaning sound over certain bumps at slow speeds. I'm also praying it's not the mag ride strut that's blown as I've already dropped some serious coin replacing parts and tires. 🤞🤞.
    I've seen a few videos and looks straightforward however is it necessary to remove the level sensor?
    If I do remove it and then reinstall everything back do I need to run VCDS to recode etc?
    As usual thanks
    Senior Member Two Rings sj9ninety's Avatar
    Nov 03 2018
    2022 M240i
    Northern Virginia
    -No recoding.
    -Make sure to unplug EDC connection from bottom of strut.
    -Yes, I would unbolt (not unplug) level sensor and move it out of the way.
    -Do yourself a huge favor and get the proper strut spreader tool.
    Dec 25 2004
    Earth
    This shows how to remove strut and top bearing
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Nov 03 2018
    2022 M240i
    Northern Virginia
    The video from Blake is great just note his method of using a 1/4 ratchet *works* but can be a pain. I highly recommend getting the strut spreader tool.
    Jul 27 2015
    Ontario
    Quote Originally Posted by MikTip View Post
    Yup, that's the one I've been referencing and studying. He makes no mention of removing the levelling sensor however there is another video floating around whereby it is unbolted from the lower control arm - just wasn't sure if I need VAGCOM for alignment adjustments etc.
    Jul 27 2015
    Ontario
    Quote Originally Posted by sj9ninety View Post
    -No recoding.
    Ugh, that one tool is roughly 40 bucks in my neck of the woods. I've got a couple of small pry tools that I hope will do the job. Hopefully it's as straightforward as it is, I'm in Ontario so the weather elements can wreak havoc on nuts and bolts etc...
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    a small "cold chisel" works fine as a spreader, just tap it in. I've done this many times in the past (I have the proper tool these days). That said, its only $10 from amazon canada... https://www.amazon.ca/Homyl-Suspensi...dDbGljaz10cnVl
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Jul 13 2018
    Winnipeg, MB, Canada
    Quote Originally Posted by bakedcorn View Post
    https://www.amazon.ca/Homyl-Strut-Su...NsaWNrPXRydWU=
    $14
    2018 Audi RS3 - Ara Blue, Black Optics
    2019 Audi SQ5 - Manhattan Grey, Black Optics
    Jul 27 2015
    Ontario
    Lol ok you got me. I was hoping to avoid the whole shipped and sold by some company in China. I'll forge ahead with my small pry bar and a 1/4 inch socket for good measure as well as a 2x3 just ....in....case. Lol.
    Thanks
    Veteran Member Three Rings Chaoscreature's Avatar
    May 26 2018
    2018 A3 Quattro, 1995 Porsche 993 C2, 2006 Jetta TDI Special Edition, 1956 Willy CJ5
    Vista, CA
    The chisel trick works surprisingly well. You can also grind down an old allen key.
    Jul 27 2015
    Ontario
    I've read somewhere that the three bolts at the top of the strut tower are a one time use item ie stretch bolts. Also the dealership recommends a new pinch bolt and nut. Does this sound legit? Has anyone reused these parts without issue. No big deal just don't want to throwing money around if it's not necessary. Thanks
    Jul 27 2015
    Ontario
    Well took the day off to get this job done....no joy. The knuckle would simply not let go of the strut. I tried a small chisel, 1/4 inch ratchet and a small pry bar...nothing. I tried the 2x4 method and still nothing. Sprayed some penetrating oil nothing. 2.5 hours later I gave up. I guess I'll have this taken care of at the local garage. Ugh!
    Nov 03 2018
    2022 M240i
    Northern Virginia
    I tried to warn you regarding the strut spreader. Purchase the $14 tool on Amazon and the knuckle will open up. The strut should slide in and out no problem.
    Jul 27 2015
    Ontario
    Ugh you sure did. I figured based on the videos on the interweb I'd have the same success but once again NOPE. Proof that I should stick to car washes and oil changes.
    I'll order the part and give it a go hopefully the tool won't snap on me and get wedged in the knuckle.
    Apr 04 2020
    Pittsburgh, PA
    I ordered a cheap $14 off ebay and it worked fine for me. You'll be good.
    Sent from my SM-G988U using Audizine Forum mobile app
    Jul 27 2015
    Ontario
    So it's the shop as I knackered up my hands this past week. They removed the strut and noticed some play in the strut mount and will replace however they mentioned they couldn't test the strut ie push it in as it's electronic and they don't have the tools etc. Is this normal for the mag ride system as it pertains to struts / shocks? There is literally no bounce in the front and the strut is not leaking nor weeping.
    When driving I can feel the ride change in the different modes ie comfort vs dynamic.
    Jul 27 2015
    Ontario
    Not the strut mount, it seems to be a bad strut, more to come....
    Jul 27 2015
    Ontario
    Update....
    Unfortunately the MR front right strut is hosed. We (shop and I)decided given the crazy expensive pricing on these units to venture the "used" part route.
    Installed and the clunking is now gone...great!...not so much. The shop also confirmed the rear MR shocks are on their way out which confirmed my fears due to considerable knocks from the rears in the past 8 to 10 months.
    The shop is beyond belief to see all four corners failing at nearly the same time with such low kilometres - 62K kilometres on the dial.
    And to top it all off the CEL popped up again which is the secondary O2 sensor and hopefully it's gone after replacement next week.
    I'm loss for words at the moment.
