Originally Posted by
Brillo
Two things that can result in burned oil smell in the cabin at stop light. One is a small oil leak on the exhaust system, and the other is bad valve stem seals. Both dissipate quickly with any speed. Have someone drive behind you to see if any smoke comes out of the tail pipe when you pull away from a stop. If yes, it's not an oil leak onto the exhaust system. What is your oil consumption like? Also, how reliable was the shop that did your head rebuild?
Not sure I understand your sentence copied below. "The timing has been changed"?? and "Changed valve changed" ??
"Also, the timing has been changed and checked. Everything is spot on.
Changed valve changed. "
I had an extensive look around saw no leak at all. I read somewhere that the oil burning smell can be caused by a bad PCV system. So I changed my pcv valve. Still the smell is persistent.
The car does smoke abit when it starts and engine shakes and misfires.
That was a typo. What I meant to say was that timing belt has been changed, and then double checked.
The rebuild of the head consisted of the valves being grinded/reseated by lapping compound.
Both of the above were done by myself as iv been doing this for my previous cars as well so nothing new for me.
The timing chain tensioner was changed and reset to the TDC marks with 16 links end to end.
Everything seems normal. During the rebuild, I checked all the valves and the lifters and none were bent or stuck.
Sent from my SM-N976B using
Audizine Forum mobile app
