Results 1 to 16 of 16
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Yet Another MMI 3G+ Update Reference / Guide
    Thanks to @spijun over at audiworld.com, I updated our NAR MMI 3G+ nav data to NAR 6.20.1 recently, and helped a couple members here get their systems updated, too. As a result of that effort, I put together (yet another) guide/reference on updating our MMI 3G+ systems (software & nav data). The first (published) draft of the PDF is here. Cheers --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Nov 14 2020
    MD
    Thanks for this very comprehensive and useful guide, very detailed. I have MMI 3G High with firmware Nav_US_K0133_3_D1 (MMI 3G High) do you know if NAR 6.20.1 8R0051884GJ is available or what will be the latest available NAR for MMI 3G High . if you can PM where I could download it that will be fantastic.
    Cheers
    2010 A5 Quattro Cabriolet 2.0T 38K miles
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Sorry but what does this update do the the mmi 3G high?
    Sent from my LM-Q730 using Tapatalk
    Ivan
    Aug 31 2014
    NW OH USA
    I don't have any direct experience with the MMI 3G High system (our B8 pre-facelift A4 didn't have MMI), but I suspect that 8R0051884GJ (NAR 6.20.1) covers these systems, as well (see, e.g., this eBay listing from the UK: https://www.ebay.com/itm/Audi-A4-A5-...B/184237872678).
    If we can confirm this, and show that the nav data update for MMI 3G High systems is essentially the same as 3GP/3G+, I'd update my guide/reference with that new information.
    Nov 14 2020
    MD
    I would like to update my maps which I am currently running ...F_NAR 5.3.4 ....almost 10 years outdated ...
    DrGER,
    Thanks, I have reached out to SpiJun will see if he rspond.
    Aug 31 2014
    NW OH USA
    After doing a bit more research on this, I've updated the link in post #1, above, to include information about the MMI 3G High release that is included in the NAR nav data media.
    I'd like to add a PNG screenshot ([TEL]+[MEDIA]) of the Red Engineering Menu main screen for MMI 3G High systems showing the latest "Current train version" as "HNav_US_K0133_3_D1" to the document -- Google hasn't found one for me, yet.
    Can someone out there do this & send along the PNG file ? Write-enabled SD card in slot #1, start Red Engineering Menu with [CAR]+[BACK]+hold, screenshot with [TEL]+[MEDIA]+hold, exit Red Engineering Menu with [CAR]+[BACK]+hold. --g
    Aug 31 2014
    NW OH USA
    Bumping this thread as I refreshed my MMI Update guide (link in first post) back in November ('21). --g
    Dec 11 2009
    '62 Mini Cooper S, '01 Audi WB B5 Sedan, '17 Toyota Tacoma TRD Pro, '08 VW R50
    MT
    Hi DrGer- My current version is HN+_US_AU3G_K0566_3. Here are photos, I hope they upload. I keep getting an error .Screen_1_241216_2211_0058.pngScreen_0_241216_2148_0035.png
    Aug 31 2014
    NW OH USA
    Quote Originally Posted by rarsop15 View Post
    Hi DrGer- My current version is HN+_US_AU3G_K0566_3. ...
    Thanks for attaching your PNG images -- they uploaded perfectly. I'm curious about the software version K0566_3 and the MU software version 0552. This looks like an early Plus main unit made in early 2012, possibly for an early B8.5 MY2013 build. What model is this in ?
    What error are you getting when you try to do the K0942_6 software update ? --g
    Dec 11 2009
    MT
    Quote Originally Posted by DrGER View Post
    You are correct, it is indeed a 2013 B8.5 S4. The error says something on the lines of update could not be performed. I am using a MacBook but use Parallels Windows to download and unzip onto SD card, is that okay?
    Aug 31 2014
    NW OH USA
    ... The error says something on the lines of update could not be performed. I am using a MacBook but use Parallels Windows to download and unzip onto SD card, is that okay?
    Post a picture or screenshot of the actual error message & we can discuss a solution. Windows on a Mac should be OK -- the problem is that MacOS Finder leaves hidden files and/or folders on the SD card filesystem that can cause the Harman-Becker software updater process to fail, so one needs to be careful to avoid opening the SD card with the Finder directly. --g
    Dec 11 2009
    MT
    Initially I have the SD card formatted thru DiskGenius. Then when I unzip the file I get this error.
    Then this error when I try to update in MMI.
    Additional screenshots of my current software
    Aug 31 2014
    NW OH USA
    First, make sure that your SD card is formatted "FAT32".
    The second image with "the medium is currently unavailable" means the REM software updater process cannot find the "metainfo2.txt" file for the update release -- it should be found in the root/top folder/directory of the FAT32 SD card. It could also mean that the SD card is not formatted as FAT32. --g
    Dec 11 2009
    MT
    The SD is for sure formatted to FAT32.. Is the metainfo2.txt found on the MMI? I dont quite understand your request, sorry! Does that first photo sent have anything to do with it? Im kinda stumped
    Dec 11 2009
    MT
    How large is the file? Im seeing 14.5 mb? Seems small?
    Aug 31 2014
    NW OH USA
    Which update are you using ? I have HN+_US_AU3G_K0942_6 over here: https://www.vwvortex.com/threads/aud...tware.9471271/
    Ideally, you should be able to extract to the SD card directly. An alternate approach is to extract to the HDD then copy the contents of the directory/folder with the metainfo2.txt file to the SD card -- but not using the MacOS X Finder ! BTW, the file ah6a-us_rev03-001.usf is exactly 10,191,808 bytes (this is the firmware code for the embedded 3G data modem that is now obsolete since AT&T ended its 3G network service in early 2022). --g
