Results 1 to 13 of 13
    Dec 29 2009
    Midwest
    Things to make an oil change the easiest.
    New Audi owner. 2020 RS3. What do you guys recommend for an oil change? Any special tools I should buy? What oil and filter? I'm very particular so I'd like to run the best oil possible for it.
    Thanks in advance!
    Jul 13 2018
    Winnipeg, MB, Canada
    Drain line for the oil filter, oil filter housing wrench, new oil drain plug and washer. I bought the last 3 from rockauto and the first from amazon. RS3 oil change is a bit more work compared to most cars due to it's oil filter literally just being a piece of paper in a housing, which is full of oil.
    Senior Member Two Rings AeyBeCei's Avatar
    Oct 03 2017
    Recommend getting a quickjack
    Jan 12 2015
    Columbus/OH
    get yourself one of these and skip draining from bottom and/or having to lift the car at all.
    '17 A3 Quattro: APR Stg 2+ ECU, APR TCU * NGK Racing Plugs * Bilstein B12 (Modified), APR sway bars, Whiteline control arms * APR Intake, Turbo inlet, turbo muffler delete, catch can, & Downpipe * Milltek catback * CTS Turbo DV * Mishimoto FMIC and pipes * DSG ICECAP w/ Mishimoto 19row cooler * STOPTECH ST40 332mm BBK * Advan Racing TC-4 18x8.5 wrapped w/ 245-40-r18 Bridgestone RE71R
    Feb 09 2008
    Quote Originally Posted by EROtero View Post
    I have been using the extractor for years on several vehicles to help keep this process clean and smooth. The only vehicle I have run across that it was not useful on was a Subaru, apparently the boxer engine sump is very different on those. The extractor has been great on all my Audi/VW models as well as a few Mazda and Hyundai vehicles as well.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by Quattrolover View Post
    Thanks in advance!
    Since the oil filter is under the car, oil extractors arent very usefull on this car, so for tools, oil and filter:
    Tools
    1. Oil filter drain tool https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2. Oil filter housing socket: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    3. Drain plug is Torx so ill assume you have a Torx socket set
    4. Oil, imho nothing beats Made in Belgium Castrol Edge 0W-40, 5 qt jugs from Walmart for ~$23
    5. Filters, OE, Hengst, or Mann
    Enjoy the machine!
    Stage 1 more than you RS3
    Dec 29 2009
    Midwest
    Quote Originally Posted by o1turbo30v View Post
    Tools
    Enjoy the machine!
    Thank you. Got everything ordered.
    Dec 25 2004
    Earth
    I have this for several years now..
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 25 2004
    Earth
    Also got rid of the plastic oil pan!
    Sep 24 2019
    Indiana
    Two post lift.
    Oct 03 2020
    San Diego/CA/USA
    T45 and T25 for the belly pan, a socket for the oil filter, oil plug tool to pull the oil plug, oil plug, oil filter + o-ring if you don't plan on going extraction method. I use a rhino ramp and it's easy.
    Dec 29 2009
    Midwest
    Just got the oil change done. Got all the parts mentioned and am running Mobil1 ESP 0w30. Very straight forward and easy on this car. I changed out the factory oil and had 2000 miles on. Now I will change every 5000. Cheap insurance in my opinion and I am particular on maintenance.
    Thank you all for the input. Im all about having the right tools for the job.
    Nov 13 2009
    the OC, SOCAL
    a good friend and an open weekend
