Results 1 to 22 of 22
    Junior Member Two Rings
    Mar 07 2018
    Pacific NW
    PCV Valve Soft Codes after replacemenet
    Hello team,
    I have been experiencing a persistent soft code (P052E00) immediately after my PCV valve replacement going on for two years now on my 2015 Audi A7 3.0TSI.
    After some forum research it seems like the issue is a stuck check valve which is part of the following 06E103207AP assembly. This could be due to it getting clogged/damaged as the original valve failed.
    This doesn't appear to be an isolated problem so it could be beneficial to replace the 06E103207AP tube/valve assembly proactively during the PCV replacement to avoid this headache.
    Has anyone else experienced this? Have you been able to clean/fix the tube valves or replacement is only option?
    Thank you
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    The exact same thing happened to me. Just replaced my pcv & still have the code.
    Are you having oil consumption as well? I've read a bad check valve stuck open can result in similar symptoms as a bad pcv (oil consumption)
    Sent from my Llama using Tapatalk
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Mar 07 2018
    Pacific NW
    LOL,
    I just saw your post as i commented on your new PCV replacement thread. I have not swapped the new part yet as I have been busy with other projects and car has hardly been driven.
    I am still having some oil burning but considering that these engines use low friction oil rings plus low viscosity oils some blow-by is to be expected in my opinion.
    I am still curious if anyone else has had this tube replaced and if the soft code went away. I am APR tuned and when I called my shop they said I'm to the latest software revision and software should not have caused the code.
    Active Member Three Rings Thomas@TAI-VW's Avatar
    May 20 2005
    B8S4 Chariot of the CLODS
    Hawaii
    Those valves are a high failure item. You can splice it into the existing hardline,otherwise you have to remove the S/C to get to it.
    2012 S4,6MT. Steering wheel/4 rims & tires/seatbelts/windshield wipers/41 psi in front tires/40 psi in back tires/CD player/AC/sunroof/oil level=full/coolant=full/no CEL/glovebox/no car payments/dusty brakes/lowbeam/high beam/turn signals/small nick in the bumper from a stone about 1/16" in dia. about 4 " below the headlight/gas in tank/clutch-brake-gas pedals.
    Mar 07 2018
    Pacific NW
    Do you know if it is a simple check valve that can maybe be cleaned using solvents or replacing it is the only option?
    I am thinking of spaying some throttle body cleaner into the upper hose tube and waiting to see if the code goes away.
    My PCV red diaphragm failed (goose honk noise) so it likely sucked in gunk from there into that check valve.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by vector78 View Post
    LOL,
    I'm about to do this and I'll let you know
    Jan 14 2016
    Wilmington, NC
    Update: I replaced my Check Valve breather tube and the soft code did indeed go away.
    Still burning oil though :/
    Active Member One Ring Carnaval09's Avatar
    Dec 28 2019
    2017 Q7 3.0T Prestige APR STG1, 2015 A6 3.0T+
    USA, NC
    Quote Originally Posted by AudiC7Owners View Post
    Hello. Did you ever find out what was causing oil burn issues…? A few moths ago replaced PCV, valve cover gaskets, breather valve along with carbon cleaning and some other preventative parts while I was at it at 135k on my A6 3.0T and while there were no codes after replacing those parts I do see that oil burn rate is still about the same as before the replacement. Can’t seem to find anything else that might cause this oil consumption as there are no other visual signs I can think of. I’ve had the car since 33k miles, has been changing oil at around 6k and it has been a bullet proof beast that never needed anything. TIA.
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    Was at the dealer the other day and they advised they are starting to see oil consumption in high mileage 3.0t motors. Especially in the q7. The Audi factory tech told them marvel mystery oil with the next oil change and the next step would be to go with a lighter weight oil. To avoid a complete engine lit tear down. My a6 at 102k was burning lol. Had been through two failed pcv as well. Was eating a quart every few hundred miles stage 2 single pulley. Rolled the dice and added the marvel mystery oil. So far 1/8 quart down after 1400 miles. Worth a try.
    Dec 28 2019
    USA, NC
    Quote Originally Posted by esimp2k View Post
    Hi! Thanks for info. Did the Audi tech mention the possible cause of the consumption? Is it due to stuck rings? I’m burning about a quart every 1600 miles using LM 5w-40. I read that failed/stuck injectors could also contribute to oil burning and now looking back I wish I pulled them to clean while I was doing Carbon Cleaning. Also, if I remember correctly from my Honda days, that sadly also burned oil, the Marvel to oil ratio was up to 20%. What are you running yours at now to see such a significant improvement in consumption? TIA
    Jun 17 2009
    One quart with a fresh oil change. Didn't seem they have a concrete reason for the oil burning. Local tech said it could be a number of things. Rings was mentioned as I recall but not injectors. I typically don't feel great about Audis after 100k miles but that's just me. This certainly has been the most reliable out of the 5 we have owned however.
    Dec 28 2019
    USA, NC
    Thanks. Well, out of my 4 Audis we currently have I have enough milage and years of ownership to speak about 3 which all have been wonderful cars. My wife's stage 1 2017 Q7 3.0T just hit over 100k and I'm getting ready to replace PCV, I'll keep an eye on what you said earlier about Q7s.
    But back to my A6, I rescanned it and strangely enough I do see the intermittent P052E00 - PCV Regulator Valve Performance code now. I only put 3k miles on this car since I replaced those components so hard to believe something would fail that early unless I got a defective part. Was wondering if there is a quick and effective way to check the breather hose on 3.0T before taking everything apart again? People talking about high failure rate of this breather hose and if I were to replace it again after only 3k splicing it for a quick replacement would be definitely a way to go. I would take an entire PCV relocation route but the kit seems to be overpriced considering FCP Euro lifetime replacement and normal lifespan of the components.
    Nov 10 2023
    Norcal
    We have the same garage. 2017 Q7. A6 Prestige (2014). And I just did the same work on my A6. PCV, gaskets, carbon cleaning, seals on injectors, but did not do the breather valve. Now I have the P052E00 also. Worse yet I need to SMOG and after couple hundred miles and many drive cycles readiness is a no go. Did you sort out the P052E00?
    2017 Q7 Premium Plus
    2014 A6 Prestige, Black optic, 20" wheels, sports suspension
    SQ5
    Q5
    A4
    Oct 18 2017
    NW Philly
    I'm also seeing a LOT of oil consumption. About 2.5 quarts every 5000 miles.
    2016 A6 stock 3.0T.
    CREC so no carbon issues to speak of as far as I can tell.
    I'm at 102k, so maybe it's time for PCV, but I have no codes whatsoever.
    Indy is using liqui-moly 5w40 and a quart of Lucas, and says just to drive it till it gets much worse.
    I think it may be time to get out before cats fail, and things get worse or more expensive.
    Apr 05 2007
    Quote Originally Posted by Spitfire007 View Post
    2016 A6 stock 3.0T.
    FWIW I too was using liqui-moly 5w40 and burning about the same. Last oil change ~5k ago I used Castrol Euro 5w40 and consumption has been cut in half. Might be worth switching things up to see if it makes any difference.
    Had PCV replaced around 75k and at 90k soft codes came back on P502E. Sounds strangely common -- I replaced 'all the hoses and valves you should replace when you're in there' too.
    today: 2016 A6 Jackal Stg1 E85
    yesterday: 1990 Audi 90 Quattro, 2x B5S4, 2 x B5A4, 1xB7A4, 1x C5A6
    Nov 03 2019
    San Francisco
    Check out this post
    DIY Updated PCV and ECU Software Follow-up
    Just a quick follow-up for those who have done or are going to do the PCV replacement themselves: Even if you don't immediately get a code for the PCV system with the older software loaded, you will at some point. Mine took four months before it started showing up, however it was a soft MIL, no CEL at any point. It has been functioning correctly with zero oil consumption, even when driven hard. The ECU however needs to have its parameters for the updated PVC operating specs updated so it doesn't think it's failing.
    You can either get the software updated by an Audi dealer, a VAS-owning independent shop, or from your tuner. If you are already tuned, you are golden.
    I went the IE tune route and that resolved my PCV soft code.
    https://www.audizine.com/forum/showpost.php?p=14817747
    Apr 05 2007
    I have IE tune and still get the soft code. e85 file last loaded approx Oct '23, 91 file last loaded approx Sep '23... so unless they've added it afterward (which I don't believe as your thread pointing this out is from 2022) I'm pretty certain it's not a slam dunk solution.
    edit: just emailed IE to see if it's something they have to manually apply, since I guess they can't assume everyone with CREC has a revised PCV.. will update once I hear
    edit2: This is why I like IE. Excellent customer service - answer in about an hour. They said:
    "Thank you for your inquiry. We get VW and Audi's most recent ECU updates and incorporate them with our tunes. This is an update that should be on there when you flash one of our tunes to your vehicle."
    So if my tune has the new PCV update, it's not doing anything for my P0502E soft code, unfortunately. Everything runs fine no CEL so just more of a very minor annoyance.
    May 28 2018
    Phoenix, AZ
    Did you guys ever find out how to get rid of the soft code?
    Nov 08 2023
    Long Island
    I have a 2018 Audi A6 with 106k got the car with 101k oil was just changed when I got it. Burned a 1/2 quart so far. It throws the P052E00 code intermittently. Water pump and thermostat were replaced at 80k not sure If I should waste money and change the Pcv valve and breather hose or just wait till it has a check engine light. Car runs fine no hissing from the engine there is suction when I take off the oil cap.
    Active Member One Ring GMigic88's Avatar
    Dec 07 2022
    Did you figure it out?
    Been a while and appears you are with Jackal instead of IE now. I’m dealing with the issue too and it’s driving me crazy. Already have had blower off 3 times.
    Quote Originally Posted by exorcet View Post
    - - - Updated - - -
    I haven’t how about you?
    - - - Updated - - -
    Any luck?
    Established Member Two Rings STXA7's Avatar
    May 24 2024
    Shelves full of crap
    South Texas
    I too had PCV failure about 2 years back ( reservoir would be low on coolant 2 days in a row) without any puddles.
    Have had a code in my 034 diag report after flashing to stage 1 file no issues.
    Will try out 06E103207AP / report back when i eventually get it in.
    I am a 034 nutswinger
    Disclaimer: I am not sponsored or affiliated with 034 motorsport, just one of many happy customers.
    Feb 28 2024
    Europe
    has anyone just tried using liqui moly and see if you still have oil consumption ? this is the fix for diesels when they do it without anything being broken.
