Results 1 to 10 of 10
    Junior Member Two Rings
    Jun 02 2020
    17 Ara on Magma S3/2005 Mercedes E320 CDI/ 2019 Rav4 Limited AWD
    Savannah, GA
    S3 Aftermarket Water Pump Solutions?
    Hey guys,
    I’m getting tired of the plastic water pump impending issue these cars have. With that said outside of this I’m very happy with my S3.
    Wanted to see if anybody has installed a stronger aftermarket water pump (not plastic) and thoughts on the part? Any issues?
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    Your answer is in Paul's video
    https://youtu.be/xFb6spS1_cw
    Dec 27 2020
    California
    Quote Originally Posted by nalinc23 View Post
    Hey guys,
    Just replaced my water pump, went with the latest revised version. Did extensive research too. Fingers crossed..the below video was crucial in my decision.
    Jun 02 2020
    Savannah, GA
    Quote Originally Posted by n8vs3 View Post
    Thanks so much, sounds like it’s just part of the experience with these cars. Oh well.
    Someone asked in the comments but nobody answered, when did the “M” revision come out? I have a 17 S3 with 23,500 mi.
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Apr 10 2019
    Consider the truism " all theories are false but some are useful". Of course you have to figure out how they may be useful.
    So here is a story to consider. Late model coolant tanks come with a cap that can leak slowly to atmosphere ie breathe. You can observe this by seeing the level slowly fall over time ( I have) without any evidence of leakage. As the coolant temperature falls some air is drawn into the reservoir. This air mixes with he coolant and increases chance of cavitation (strong impeller vibration) and ultimately damage. Plastic pumps are not as resistant as the old CI ones (which also failed).
    So maybe make sure that the coolant level stays between the marks.
    Jun 02 2020
    Savannah, GA
    Quote Originally Posted by morris39 View Post
    Not a bad theory and at the very least cheap insurance!!
    Jul 10 2016
    Quote Originally Posted by MikTip View Post
    Look at the pic, the housing is still plastic.
    For 8P A3, there are fullmetal cast aluminum water pumps.
    Jun 02 2020
    Savannah, GA
    Your first post said "I’m getting tired of the plastic water pump impending issue these...anybody has installed a stronger aftermarket water pump (not plastic)"
    You never asked about the thermostat housing...
    Has the water pump on your car failed?
    I wasn’t the one that wrote that but no it has not yet but I’m assuming it’s a matter of time.
    Jul 10 2016
    Yes. Water pump was replaced at 13,000 miles because it was leaking form the plastic housing...
