Results 1 to 6 of 6
    Mar 29 2021
    Big rapids
    Audi A4 reliability questions
    Out of a 2011 Audi A4 2.0t Quattro premium plus and a 2012 Audi A6 3.0 and a 2011 Audi A5 2.0 which is more reliable ?
    Senior Member Three Rings Kylet21's Avatar
    Dec 19 2016
    2012 TT RS
    Milwaukee, WI
    A6 3.0. Those engines are some of the best Audi has ever made.
    Jul 16 2018
    Atlanta
    Anything without an EA888 Gen2 2.0T.
    Yeah, the supercharged 3.0T is very highly considered. But nothing is 100% solid, and anyone could be the reason we have to keep statistics.
    2012 was the first year for the C7 with the electromechanical steering rack. You might want to check in on that, as J500 thread one after the other seems to be popping up lately for the B8.5 owners.
    But that 3.0T A6 will run rings around any 2.0T car. Had a 2014 (?) loaner for a week, was a blast. And easy to bump up the power with a pulley swap.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    The 3.0 blown or not, is miles ahead in reliability of the 2.0T. The problem with the N/A 3.0 is it does nothing well performance or economy wise. It has the fuel mileage of a 4.2 and almost the same power as the 2.0T. I had a '12 Q5 come through the shop today with the NA 3.0. The acceleration was lack luster to say the least and the logged fuel mileage was pretty abysmal (17mpg indicated). Does the A6 you're speaking of have the NA or blown 3.0? I'm not sure of all the engine options the C7 had. I do know the FWD C7s still have the lousy CVT, at least when it's behind a 2.0T. If it has that trans, then hard pass and deal with the A4 and slap a set of chains and fresh trouble charger on it.
    The rest of the cars reliability will be the same though.
    B6 S4, B8 A4, 8P A3, and something, something.
    Mar 29 2021
    Big rapids
    The a6 is a 2012 AWD 8-Speed Automatic
    3.0L V6 24V GDI DOHC Supercharged, I got a hold of the guy whose selling it but replied extremely slow on the other hand the 2011 a4 the guy has paperwork of recently having new timing chain and tensioner along with new water pump and has 110k miles
    Jul 16 2018
    Atlanta
    Quote Originally Posted by RPMtech147 View Post
    I assume you mean the 3.2L V6. There was not a N/A 3.0L V6 (maybe if you go back far enough, but not since the mid 00's). The 3.2L was not used in the B8.5 or the C7.0. The Q5 was its only use in the B8.0 for MY11 or MY12 (also used in the MY10 A5; all three B8 products used it in MY09).
    Any FWD Audi should be a pass.
