I tried removing my front brake caliper today to replace my front rotors but already hit resistance as one bolt looks like is stuck.
I managed to get the bottom one off but the top bolt which is just beside the brake fluid hose won’t budge even after using penetrating oil and heating up with a torch.
Examining the other bolt that came out it looks like there was some sort of thread lock or anti seize used which is stuck in the threads.
I saw some recommendations to use a breaker bar to open stuck caliper bolts but I don’t have enough wiggle room with floor stand and also limited turning radius. I am guessing will probably need to lift the car off the ground to use the breaker bar.
Should I just give in and bring it to a shop /Audi dealership or is there something else I can try?
