The steering rack on my 2002 1.8TQM Avant with 172k has a slow leak, and even with draining all the fluid and running it with stop leak for 2 months, it continues to drip.
My local pic-n-pull has an 2002 A4 1.8tqm sedan is about identical to mine and its rack looks immaculate and I can get it for $33. I'm preferable to installing a used genuine Audi rack than taking a chance with a remanufactured one. The whole car actually looks like it was well maintained with all 4 corners in tact.
The steering wheel is not centered though and it's locked by the ignition.
I know that when a new or rebuilt rack is shipped, it is centered and locked with a screw that you're supposed to remove right before installation, paying attention to keeping it centered.
Questions:
1. On the diner vehicle, after I disconnect the steering column from the rack, should I try and center the rack by turning one of the front wheels and eyeballing center? Is this even necessary during removal? Otherwise, is there a good way to make sure the rack is centered once its removed from the vehicle?
2. What size screw/bolt do I need to install on the rack to lock it in place once it is centered?
3. Before installing the replacement rack, should I drain all the stop leak from my power steering reservoir and try and flush the line that feeds the rack by filling the reservoir with new fluid and keeping it topped off while the car is running and let the disconnected line that goes to the rack drain into a bucket?
Is there anything else i should to consider before removing the rack from the doner vehicle and installing it onto mine?
Sent from my SM-G950U using Tapatalk
