Results 1 to 10 of 10
    Established Member Two Rings Popperoni's Avatar
    Oct 18 2020
    2002 Chevrolet Malibu
    Minnesota
    2013 Audi A4 Quattro, how to check what engine version I have?
    hello all, I have a leaking fuel injector in cylinder 3 that caused misfires and my engine to stall on the highway. peaked inside cylinder three and saw that when I primed the fuel pump, gas dumped into the cylinder. So now I am replacing all fuel injectors, all spark plugs, along with an oil change. I have never replaced my fuel injectors before, so I am looking at YouTube videos online. The humble mechanic posted a great video showing the version three engine fuel injector repair, but I do not believe that my 2013 car has the latest version. where can I check what version my engine is? Or does anybody know if it’s the same process as a version three engine?
    also, what else should I do/replace while replacing my fuel injectors? Thanks.
    Jul 16 2018
    Atlanta
    You have either a CAEB or CPMA in a US MY13 A4. Is the intake manifold made of plastic or metal?
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    What about the engine code from the production sticker in the spare wheel well? What does it show? Also, look here for original part numbers: http://www.oemepc.com/audi/parts_lst...art/736/lang/e
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Oct 18 2020
    Minnesota
    Quote Originally Posted by DrGER View Post
    Oh I did not know it was there, I will look when I get home, thanks.
    Oct 18 2020
    Minnesota
    Quote Originally Posted by Smac770 View Post
    It's the CPMA engine.
    Jul 16 2018
    Atlanta
    So the CPMA engine with the two-piece metal intake manifold. Make sure you get the correct injectors, 06H 906 036 N. The Bosch catalog part number for them is 62823; they are physically marked as part number 0 261 500 164.
    There's this video on the removal of the metal manifold - www.youtube.com/watch?v=fQZj85Db_Kc
    But he's a shop mechanic, and makes up what he cares to be careful with and what to disregard regarding the actual process. It's also not going to provide you any of the torque specs you need, etc. I suggest you pay for a day to erwin.audiusa.com and get the actual legit documentation on the process, and combine that with the experience of the video to accomplish the task. The intake manifold is covered in the Fuel Injection and Ignition document, but get them all. You're going to need the Engine Mechanical, etc, as different bits of the overall process are documented in different documents.
    Oct 18 2020
    Minnesota
    Thank you to everyone who helped me sort this out. Replaced all of my spark plugs and fuel injectors along with an oil change. Runs great now. Fingers crossed that another problem doesn't occur at least for a little while, haha.
    Oct 18 2020
    Minnesota
    Although I should add, when I started the car for the first time after repairing, it had a rough go at first which I wasn't surprised, I'm sure there was extra fuel in a cylinder or in the line somewhere, I don't know, I'm not crazy good with this stuff. But I got a whole mess of warnings through my OBD reader. Like I said though, car ran just fine after a couple of seconds. I went ahead and cleared the codes, and have put about 100 miles on it since then and no issues, even better MPG than when I first bought it. Apart from that I smell a stronger scent of fuel when I have it parked.
    Don't know what to say, may have a certified local dealer look over it for me.
    Feb 15 2016
    Cambridge,Ontario
    its leaking somewhere.. you should not smell gas ..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 18 2020
    Minnesota
    Drove it again today, did not smell gas this time. I don't know, the car sat nearly a month before I worked on it, not sure if that has anything to do with it. I should note I did not smell fumes in the cab ever, just standing by it in the front. It honestly could have just been me being skeptical that I did a good job or not, and observing the car more than I usually do. Also, no CEL on yet, and the fuel economy is great. I am no mechanic but I feel like if something was leaking the computer or I would have noticed something different. That being said, I ordered a VCDS cable, it comes Friday. I am not driving the car until that comes and I can check some data. Problem is I don't really know what data points to look at.
    You sound like you really know your shit, haha. Would you by chance happen to know what metrics I should watch to indicate if the fuel injectors, fuel rail, HPFP, and if the engine, in general, is running correctly? Or at least point me in the direction of a good post? I trust what you tell me so I figured I should ask! I also had a P0299 code the day I bought the car back in October, but like I said, the car runs fine so I suspect it was a fluke code or a sensor issue. I would like to inspect that too.
    Thanks sir I really appreciate it.
