Originally Posted by
mstevens911
I am getting a dash light for the third brake light being out. The dash light comes on sporadically with no real rhyme or reason to heat, cold, bumps etc. But when the warning light comes on, the third brake light is still working. If have read other posts about the third brake light going out occasionally due to loose connections and receiving the warning. But I just get the warning and the light is still working.
Anyone else run into this issue?
Yes, I am also seeing this same fault on my 2013 Allroad. Warning light and loud ping from the dash, but when I check the third brake light it is working fine...all 18 bulbs are lit. Some people have suggested that corrosion on the leads is causing the problem, but corrosion would cause the light to not function, so I don't see how that is the problem. Did you ever figure out a fix for your allroad? Any others care to chime in?
