Have any of you had any negative experience with R1 Concepts Carbon GEOMET brake rotors?
I recently did brake pad and rotor replacements on my '06 A4 F/R and '12 Q7 F/R, replacing both with the R1 Carbon rotors and different Hawk and R1 branded pads. Within the last 1K miles since changing both, the A4 with ceramic pads has steadily lost braking performance and also has developed a wobble in the front (pretty sure its warped front rotors). The Q7 has steadily lost bite, requires much more peddle pressure and overall lost performance with Hawk LTS pads. The common denominator between both systems is the R1 rotors...which come highly reviewed. I previously used their E-Line rotors on a Japan spec Honda with great results (aside from surface rust). Visually compared to stock they look great and thus far have not rusted...but the gradual loss in brake performance since new is noticeable and concerning.
I swapped the front A4 pads back to OEM which helped a little bit with both of the loss in performance/wobble, and plan to turn the OEM rotors on both cars and remount them in the next month...just wondering if others may have a similar experience.
