Originally Posted by
codemode
You would have to change all the airbags to dual stage, code a loooooot of modules. And don’t forget the instrument cluster, since they are not interchangeable (RB4 vs RB8). Also that would be a massive massive undertaking. I’m not sure about the lights doe. That wouldn’t be plug and play. Also B7s have adjustable lights when cornering. It also has a TPMS. I think they also use the electric motor mounts (some of them??). They also have some additional relays such as the rear defrost (you would have to swap the climate unit as well). That is what I can remember off the top of my head.
This is generally accurate, but the lights aren't ALL the AFS (moving when you corner), so you can recode the CECM to disable the cornering part I would imagine, as the non-cornering xenons were an option in canada and europe.
Rear defrost has a relay somewhere as you said, likely in the relay panel behind the drivers kick panel. Its an easy thing to retrofit (I did it), or you can just use the b6 climate control panel as they're more or less identical minus the rear defrost relay. The electric motor mounts are only for Tiptronics but thats a ECU thing its not something you'd need to worry about most likely.
Cluster you'd probably want to pop in a B7 RB8 one though since, again, they're the exact same size and shape and it would just be easier to reprogram a b7 one to have your VIN and mileage than to try to make an RB4 one to play nice with all the B7 stuff. If you're ready to swap all the wiring then go for it. I don't see any major hurdles in it, just test it all before you put the interior back together, haha. And just keep your B6 seats, the b7 seats aren't anything special except you'll have to adapt or disable the passenger occupancy sensor.
