Hello, please read this over and any help you can offer would really be appreciated. I've been chasing this around and done all the testing I can without replacing any new sensors etc. The car has been smoke tested using a professional grade machine in the last few days. No leaks.
So I have this issue that has been happening for a while now...as a result the car has not really been driven much and I have been driving my other Audi.
This 2008 A6 4.2L Multiple misfires most the time after a little while when test driving. Yellow check engine light comes on, blinking, then usually constant. It will drive fine after I clear the codes, but then after a short time it will start running rough and the same cycle will repeat which is normal for the problem not being resolved...
I have Ross Tech VCDS so I have run many reports over the last few months. It has lost power a couple times and I am aware of the voltage issues, etc. that are created from that and I clear the codes and keep trying to focus on the misfire and check engine warning issues.
Five Days Ago, I have the same ongoing issue as I drove to my friends shop to smoke test it because I was told I have a vacuum leak. My Engine Measuring blocks are all over the place with fuel mixture issues where it runs weird and I believe bad mileage, and if I clear the codes it wont run rough until it goes wacko again, running rough and the whole process repeats. 5 days ago I documented:
So this data is all I have from this reoccurring problem(s). Any help you can give would be really appreciated.
Main Engine Faults are coming usually from cylinders #1 and #7, or sometimes a new report and I get one on cylinder #4, previously some time ago I have had it on all of them, #1, #4, #7. I also sometimes get this 008753 - Oxygen (Lambda) Sensor B1 S1 code fault (see snippet from the report):
P2231 - 004 - Signal Shorted to Heater Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 166986 km
Time Indication: 0
Date: 2007.03.08
Time: 14:45:00
Freeze Frame:
RPM: 3315 /min
Load: 92.9 %
Speed: 104.0 km/h
Temperature: 74.0°C
Temperature: 9.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.589 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - MIL ONVCDS
Self-Diagnosis Log
Wednesday,17,March,2021,17:41:00:02327
Page 5
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 166986 km
Time Indication: 0
Date: 2007.03.08
Time: 14:45:04
Freeze Frame:
RPM: 2678 /min
Load: 63.9 %
Speed: 112.0 km/h
Temperature: 74.0°C
Temperature: 9.0°C
Voltage: 13.589 V
Readiness: 0010 1100
My spark plugs are less than 10k old, I have troubleshot my coils previously and replaced one.
When I did my valve covers recently I cleaned the oil out and cleaned all the spark plugs again. I've done this a few times in the last 10k, although I haven't done this recently in the last few months.
It was running so rough last week (as it has for a few months) I was concerned about driving it. I fired it up and limped the drive to my friends garage where in transit I managed to get all the codes cleared after a few rounds (three sets of scans and clears because it took 3x to do so, the last 5 miles it ran fine after clearing faults of course so as I limped it there about 10 miles away total). By the time I got there I was running a clean report, no check engine light and I arrived and smoke tested it with a professional machine with UV mineral oil to check for vacuum leaks. I had no leak issues during the smoke test. No leaks and still no codes as I ran reports again. Car ran fine with no faults. Drove it home fine with no issues.
The next day I hopped in and after about .25 miles it repeated all the same core problems repeating as before: rough running, misfires, check engine light coming on, etc. This is the same reoccurring pattern. Not really drivable. Once again, I turned it around and parked it. Ran my report and it just came up with just one misfire this time on cylinder #4 opposed to the previous reports of cylinders #1 and #7, and I also have another fault code of 008753 - Oxygen (Lambda) Sensor B1 S1
P2231 - 004 - Signal Shorted to Heater Circuit - Intermittent as I mentioned above.
Here are the before and after smoke testing reports. As I said I also checked out the changes on the engine measuring blocks that did lots of correcting after codes are cleared. Definitely attempting to compensate but I do not claim to be an expert on this. My friend told me I just had a vacuum leak causing all of this but I thoroughly checked it it out and saw absolutely nothing. Here are the reports from on the way to the shop and then tonight's as it failed again:
5 days ago pre-smoke testing and before I cleared all the codes:
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 21.3.0(x64) Data version: 20210226 DS325.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Mileage: 167000km-103768mi Repair Order: 1
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
52 53 55 56 61 62 65 72 77
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
-------------------------------------------------------------------------------VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine Labels:. 079-907-560-BVJ.clb
Part No SW: 4F1 910 560 E HW: 4F1 907 560
Component: 4.2l V8/4V 0010
Revision: 74H04--- Serial number:
Coding: 01050009190F0120
Shop #: WSC 02335 758 00200
VCID: 2517F2E939E19753DC5-8070
8 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 166851 km
Time Indication: 0
Date: 2021.01.07
Time: 22:43:52
Freeze Frame:
RPM: 2678 /min
Load: 63.9 %
Speed: 112.0 km/h
Temperature: 74.0°C
Temperature: 9.0°C
Voltage: 13.589 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 166851 km
Time Indication: 0
Date: 2021.01.07
Time: 22:43:52
Freeze Frame:
RPM: 678 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 47.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000773 - Cylinder 5 VCDS
Self-Diagnosis Log
Page 3
P0305 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 166851 km
Time Indication: 0
Date: 2021.01.07
Time: 22:43:52
Freeze Frame:
RPM: 640 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 50.0°C
Voltage: 14.351 V
000775 - Cylinder 7
P0307 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 166851 km
Time Indication: 0
Date: 2021.01.07
Time: 22:43:52
Freeze Frame:
RPM: 640 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 50.0°C
Voltage: 14.351 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:VCDS
Self-Diagnosis Log
Page 4
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 166929 km
Time Indication: 0
Date: 2007.03.02
Time: 12:03:36
Freeze Frame:
RPM: 1087 /min
Load: 44.3 %
Speed: 0.0 km/h
Temperature: -1.0°C
Temperature: 2.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.176 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 166986 km
Time Indication: 0
Date: 2007.03.08
Time: 14:45:00
Freeze Frame:
RPM: 3315 /min
Load: 92.9 %
Speed: 104.0 km/h
Temperature: 74.0°C
Temperature: 9.0°C
Voltage: 13.589 V
000772 - Cylinder 4
Self-Diagnosis Log
Page 5
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 166986 km
Time Indication: 0
Date: 2007.03.08
Time: 14:45:04
Freeze Frame:
RPM: 2678 /min
Load: 63.9 %
Speed: 112.0 km/h
Temperature: 74.0°C
Temperature: 9.0°C
Voltage: 13.589 V
------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 A HW: 09L 927 156 C
Component: AG6 09L 4,2 FSI USA 0010
Revision: --H03--- Serial number: 4339229
Coding: 0000002
Self-Diagnosis Log
Monday,22,March,2021,21:01:11:02327
Page 2
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 167026 km
Time Indication: 0
Date: 2007.04.02
Time: 10:17:42
Freeze Frame:
RPM: 2844 /min
Load: 84.3 %
Speed: 65.0 km/h
Temperature: 94.0°C
Temperature: 18.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.351 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 167026 km
Time Indication: 0
Date: 2007.04.02
Time: 10:17:42
Freeze Frame:
RPM: 2844 /min
Load: 84.3 %
Speed: 65.0 km/h
Temperature: 94.0°C
Temperature: 18.0°C
Voltage: 14.351 V
Readiness: 0010 1101VCDS
Self-Diagnosis Log
Page 3
Coding: 0000002
Your help is greatly appreciated. Thanks in advance.
