    May 01 2018
    Virginia
    Weight of S4 VS SQ5
    Currently I hold the fastest time for the SQ5 @ 11.001@124.55 But was curious what the weight of these low 10 second S4's are. I have every bolt on, only thing I can add is probably meth for cooling, and a ported blower... Has anyone weighed one with all the seats and trunk stuff out etc??
    List your weight and what was removed?
    I am sitting at 4025, no driver. all panels removed, seats except stock driver seat, console, sub etc. removed. 9lb battery, AG 20lbs wheels
    2014 SQ5 DP/104 Octane 11.001 @124.55
    2019 TTE RS3 FBO
    2021 GLC63 S AMG
    Junior Member One Ring
    Jul 04 2018
    Arizona
    Mine isn't a low 10 sec car. But I have weighed mine, so you can get some sort of baseline.
    3880lbs without me in it, using a certified truck scale. Full tank of gas, spare in the trunk, full interior. 2013 S4 Manual (I think manual is a bit lighter than a DSG) and aftermarket wheels that are 23ish lbs each (not sure what stock is).
    Jul 31 2016
    PA
    Keep in mind aerodynamics play a big factor too, the s4 is more streamlined than the flying brick of a q5.
    Even if both cars weighed 4000 lbs, at 120 MPH a q5 would be spending 124 hp just to overcome drag, and at 130 MPH, that jumps to 155 hp. This is a Cd of 0.33 and 28.417 sq ft. frontal area.
    Even if you could somehow get the car to 3800 lbs, it only drops things to 123 hp and 154.3 hp respectively.
    An S4 with a Cd of 0.28 and a frontal area of 23.681 sq ft, only needs 92.6 HP to overcome drag at 120 MPH and 115.6 to go 130.
    In other words, it takes a lot more power to get the big SUV moving at the same speed as an S4, and weight almost doesn't matter at those speeds at a certain point, which is probably what you are seeing now. Drag is now your primary concern, and there just isn't much you can do there other than lower the car, and even that won't help that much.
    Ported blower would be the best bet for you. It's likely worth enough to get you over that hump.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    So cut the roof off and put one of those old school hot rod windshields on that are like 6” tall. Then post pics. Please.
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Quote Originally Posted by djn876 View Post
    great explanation... enjoyed the read
    - - - Updated - - -
    Quote Originally Posted by esimp2k View Post
    lol +1
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
