Results 1 to 7 of 7
    Junior Member One Ring Dad_fast's Avatar
    Dec 07 2020
    Florida
    Difference between various releases of the 4.2L V8
    Does anyone know, or have a reference of, the different components and variations of the Audi 4.2L V8? I'm curious to know what makes the difference between an R8 V8 and an S4, RS4, S5, etc. The power numbers are quite different so it begs the question.
    Veteran Member Three Rings bluebull's Avatar
    Aug 28 2014
    2017 R8 Nardo boosted with VF; 2017 SQ5; F250
    Portland, OR
    RS4 = BNS block with forged internals if I’m not mistaken
    420 hp/~330awhp factory #s
    TVS1320 APR, TTX36 Ohlins coils, DXD Flywheel + Clutch, JHM Shift Goodies, Euro Sport Reacecloth Seats, 034 mounts, Stern UCA, JHM full (resonated) exhaust with v-band test pipes and HF cats, JHM short shifter, Rotiform 19x10 with 275 PS4S, Fender to ground is 25.5", ceramic coated and PPF.
    Dec 07 2020
    Florida
    I see, so they are not all the same blocks? I didn't realize that. Thanks for the reply.
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    They’re very similar, however the coolant channels in the BNS block vary from the BHF (S4) as well. There’s a RS4/R8 has direct port injection too so they’re subject to carbon buildup, where the BHF is not... I also believe that there’s a different cam profile and compression. There are also variants of the 4.2 with less power than the S4 BHF block that were found in the Q7/A6/allroad ... can’t remember if there’s one in the A8 or not. These engines have the chains on the front if I’m not mistaken.
    I’m not sure if BHF heads can be swapped onto these variants, but my suspicion would be NO as the timing is driven from the other end of the engine which would change the bearing/crank orientation.
    Headers to Milltek non-res catback, LWFW, LWCP, JHM synchros, 034 Mounts & end links, BC Racing Coilovers, Stern adjustable UCAs, RS4 Hotchkis anti-sway, JHM 93 tune and short shifter trio, Brembo 18Z, 19" RS4 reps.
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    The Non FSI 4.2L V8 are closely related and the FSI 4.2L V8's are closely related. The wider gap is between the Non FSI version vs the FSI version. That transition started with the B7 RS4 and made its way into the S5, RS5, Q7, R8, etc.
    Dec 07 2020
    Florida
    Thanks, guys! That helps.
    Feb 03 2019
    Hertfordshire
    There’s also differences across the years in terms of the PCV system within the valve cover..
