Originally Posted by
Goodman2265
I considered the M550i because its the N63TU2 which has most of the issues fixed and actually I have a lot of friends that work at BMW and they said they haven't seen any come in with issue. Its just I found a white on red S6 with low miles and it looks hot. Other option is a RS7 but i have to shop around more for one of those thats clean. Looked at S8's briefly to because I currently have a Cadillac and i love me a luxo-barge
I have a '17 S6, and can tell you what I've had happen/done maintenance wise. The poster above had the general points right, but a few of the details are a little off.
The turbos failing is probably the most common "big ticket" failure on the 4.0T. Some have it, some don't, and if it seems more common than you'd think, remember this is an enthusiast board, so many people are over OEM power levels. I will say that there isn't a direct correlation between tuning it and the turbos dying, it just seems to happen to some and not to others. If the turbos haven't already started failing, and by that I mean damage to the bearings, removing the screen is the simplest insurance against that happening. Unfortunately, it is a very involved process to get to the screen itself, and most will replace the PCV while they're in there, as the PCV is another common failure. Many people opt to upgrade when/if theirs fail, as OEM turbos are 2-3x more expensive than good quality aftermarkets, and it allows you to go a size up and save serious $.
The mechatronic failure is only present on the S6/7, as the other cars have the ZF8 automatic. It is another thing that, while more common on earlier, pre-facelift models, can and does happen randomly to anyone, stock or modified. I have some mild mech issue symptoms myself, but the good news is a full repair kit can be had for $725 shipped in the US, and the repair is not difficult to do at all, the trans stays in the car and nothing except the subframe crossbrace and mech unit itself actually have to be removed. I don't have any codes, but I do get some 2-1 shift clunkiness and hesitation to shift when the DSG is cold. I'm doing it now instead of letting it progress to the point where it actually affects the drivability of the car.
I have had 1 motor mount fail, and it was replaced under warranty at around 38k. With the state the car is in now, I don't have a warranty and I have no need of the complex, electro-mechanical fluid filled mounts that Audi built these cars with, as my 4-cyl mode has been disabled for the last 10k miles and I don't miss it at all.
Another note on the oil screen, even people with the newest revision have had failures, so it's not a guarantee. I believe that the most recent version started coming installed from the factory in the middle of the '18 model year, or thereabouts. My 2017 did not have it, and I had it removed when doing turbo upgrades and went with the JHM screen relocation/replacement kit that trades the single, deeply buried and poorly designed screen for 2 easily accessible, user serviceable filters. There is great debate on the necessity of the screen or a filter at all, and many people have removed it completely and never had an issue.
I won't speak on the Bimmer, as I don't really have much of an interest in them except for how good they look in my rearview mirror
. Whichever way you go, enjoy your new ride! There are a lot of really knowledgeable guys on here, it's a great community and we'd be happy to have you join us.
One more thing before I go, skip APR and get a DS1. There are more than a few threads discussing the differences and benefits, including many people who have come over from APR, and the only reason APR is relevant at all, is that they slashed their prices. Even with that, if you care about your car and want a little or a lot of flexibility, the DS1 is the way.
Sent from my Galaxy S20 Ultra 5G
