Results 1 to 15 of 15
    Jun 28 2015
    St. Louis
    Q5 sound absorption foam pad in engine bay - What is the part #?
    My 2015 Q5 has two black foam pads, apparently sound absorption insulation, near the firewall on both the right and left sides of the engine bay. The right pad has been chewed up by a rodent. I have searched Audi parts sites and have not been able to identify the part name or number. I called my Audi dealer and described the pad. One side appears to sit on top of the shock mount and the other side is draped down to the side of the engine. The pad is attached by two plastic fasteners.
    Assuming the dealer found the right part, he said the price is $109.99, but declined to give me the part number per dealer policy. I figured it would be pricey but $110 for a small foam pad is crazy.
    I have it circled in red in the attached photo. The second photo shows my actual damaged pad.
    Can anyone provide the part #? Thank you!
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    S/N: 8R0863801A
    Price in EU is 34 EUR
    Jan 08 2016
    Los Angeles, California
    On sale right now from Audi Columbus:
    https://www.partscolumbusaudi.com/p/...xoC0-AQAvD_BwE
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Oct 10 2010
    Sarajevo, BiH
    Quote Originally Posted by Pittdawg View Post
    Can be cheaper, I gave him the catalog number to a search on the Internet
    https://www.genuineaudiparts.com/oem...abs-8r0863801a
    Jun 28 2015
    St. Louis
    Thanks for all the replies!
    Comparing this part's photos to the part in my car, I am not sure they are identical. Here is another picture.
    Can anyone confirm?
    Oct 10 2010
    Sarajevo, BiH
    Quote Originally Posted by robstl View Post
    Can anyone confirm?
    You got the part number that you asked
    Compare pictures online,
    Good luck in searching and checking the part number, let me know if you find the correct part number
    PS: I have a suggestion for you, take out that part and look for the serial number on the inside
    Jun 28 2015
    St. Louis
    Correct part # is 8R0863802A
    Quote Originally Posted by spijun View Post
    The correct number for this part is 8R0863802A, which is for the passenger side. I assume 8R0863801A is for the driver's side.
    The only way I figured this out was by removing the part, taking pictures, then comparing to the online photos. No descriptions online say this is for the passenger's side. The section on my part that had the part number stamped into it was chewed away by the rodent.
    Thanks again for the initial part # suggestion. I never found it or the correct part # in my numerous searches previously and I have yet to see a diagram that includes either part.
    Oct 10 2010
    Sarajevo, BiH
    Here:
    Jun 28 2015
    St. Louis
    Here:
    That must be for the European models. Mine is US.
    Junior Member Two Rings
    May 09 2017
    Minneapolis, MN
    Were you able to source this part and fix your problem? I’m having the exact same issue on a 2015 US SQ5. Varmints ate the tasty cover over the passenger side strut done. This *looks* like the correct piece for me, I’m hoping you can tell me the correct piece if this isn’t it.
    Jul 16 2018
    Atlanta
    Those are not near the firewall, they are near the plenum chamber wall. The firewall is at the base of the windshield. Either way, it's the item [6] on the already linked ilcats.ru page:
    https://www.ilcats.ru/audi/?function...20&language=en
    so 8R0 863 801A for left, 8R0 863 802A for right - https://parts.audiusa.com/p/52226998/8R0863802.html I wouldn't advise paying MSRP to Audi for it; you have the p/n, search around.
    Dec 01 2020
    2014 Q5 2.0T
    Quote Originally Posted by Jim_MN View Post
    Be careful with all those leaves you are letting sit in the cowl. Also there is a drain line under the cowl and I bet it is covered in leaves which can get you in big trouble. Once a year or so I remove that and take a vacuum and suck them all out.
    May 09 2017
    Minneapolis, MN
    Quote Originally Posted by silver_tt View Post
    Thanks for the reminder! I went outside and cleaned the cowl immediately, believe it or not. :) Used my cordless leaf blower and cleaned it right out.
    I also called Audi Mpls with that part # and they confirmed it was the correct part #, but it's $151.66 from them. I'll look for a better price in the next few days.
    Dec 01 2020
    2014 Q5 2.0T
    Part is $89.60 from a real dealer:
    https://www.audiusaparts.com/oem-par...abs-8r0863802a
    Established Member Two Rings 5000S's Avatar
    Aug 26 2020
    I recently had the same problem with the other side. The foam must be tasty to mice. I remember when they made foam packing peanuts out of
    corn, so that could be the same thing here, tastes like food. My damage was not as large, so I just trimmed it away with a knife.
    I use snap traps and have caught 2 in the last month. My Audi is kept in a large farm building.
