Results 1 to 10 of 10
    Jan 22 2021
    CA
    Coolant temperature: Too high warning
    Got this message yesterday while driving. Loud Fan comes on as soon as it appears. When at a stop light and car is idling, fan will turn off and no more warning light; then I start driving and warning will eventually appear again after a few minutes. I checked for codes and have none. Taking the car to the dealership this weekend but wanted to know if anyone has experienced this? I’ve searched through the forums but it’s mostly people that have the fan stay on even after ignition is turned off, which for me it has not done that so not sure if it may still be the thermostat or water pump. Also the engine temp seems to be working as normal.
    Jan 22 2021
    CA
    Forgot to mention 2018 Audi S5 with nearly 38K miles. I am on APR stage 1 with CTS intake and Intercooler
    Junior Member One Ring
    Aug 09 2020
    When I had this on my 2018 RS5, it was because there was a coolant leak. Coolant is highly pressurized and any air that gets into the system will cause the coolant to dramatically increase in temperature. Do you see any clear fumes coming from under the hood when you pop it open after driving? You can also smell coolant if it's actually leaking.
    Jan 22 2021
    CA
    No coolant leak, it’s actually been at the dealership since Saturday. They can’t find anything wrong or any leaks so they’re going to just replace the entire cooling system.
    Jun 26 2021
    Romania
    Same problem with my s5 . I changed the thermostat and one day the coolant temperature is high and next day all is fine . I don’t know what is the problem
    Senior Member Three Rings c99's Avatar
    Feb 28 2009
    RS5 2.9TFSI - dead engine
    EU, CZ
    Quote Originally Posted by Alexfica04 View Post
    So it is water pump.
    Jun 26 2021
    Romania
    I don’t have any leak on water pump so why sometimes is working and sometimes not , I saw another thread and they speak about coolant valve solenoid .
    Jun 26 2021
    Romania
    I solved the problem after i changed switching valve (solenoid valve coolant )
    Jun 12 2022
    California Us
    Hi Alex,
    By any chance if you can post the link to get coolant solenoid valve here? I can't seem to locate it on the internet, thank you.
    Established Member Two Rings V6Quatt's Avatar
    Dec 16 2011
    England
    I have heard the housing can leak too was there any pink residue when opening the bonnet
