Results 1 to 23 of 23
    Oct 23 2015
    Australia
    Anyone here with a user review on Vogtland coilovers ?
    Heidi,our new B8.5Q stablemate to Wolfie (sig below ) rides badly on her S-line sport shocks/Eibach pro spring mod we quickly discovered after a week of ownership..its the only mod the previous owner did that's disappointing.
    We have a direct comparison with Wolfie's Vogtland coilovers on the same sealed minor road into our rural area.No competition,hands down,Wolfie wins.
    Don't know if the shocks are shot or its not a good combo...but were thinking of ditching this setup and going with V/land c/overs.We're very happy with them on Wolfie after over 100k miles on them (pity about his engine,but that's another story-open heart surgery may be his only chance.. )
    I have the drum that the Avant setup is preferred as the sedan rears as supplied tend to lose tension and the rear end wallows etc...Makes sense,we upgraded the rear springs to 750lb Hyperco's on the B7 about a month after fitting.
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Oct 23 2015
    Australia
    Ecs no longer stock these but other sellers do.
    I can buy them direct from Vogtland for a very keen price inc freight to Australia....
    Still would like to hear from anyone out there who fitted these.
    Veteran Member Three Rings shreddykrueger's Avatar
    Feb 14 2016
    S4 Avant
    I’ve had vogtland coils on my avant for ~3yrs now. I’ve been very happy with them, they handle the shitty Colorado roads extremely well. I blew out the front right shock, but vogtland warrantied it and made the process super easy. I’m running mine all the way up, wheel gap is minimal and no issues with rubbing
    S4 Avant (6MT)
    RCP dual pulley | AWE touring | JHM catted/baffled DP's | AEM water/meth | Ringer Stage III | RSNAV | Vogtland Coilovers | many other tings
    Oct 23 2015
    Australia
    Sounds good,I'd defin go with the avant model for the beefier springs and maybe different rate.
    Btw,pretty cool looking avant you have there.....are they 19 or 20's ? I'm even thinking of swapping back to 18's
    Feb 14 2016
    S4 Avant
    Quote Originally Posted by Ringsby4 View Post
    Thank you, s4 avant swap on 19” s5 rotors
    S4 Avant (6MT)
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    Ringsby4, my guess is your bad ride is related to the shocks not being compatible with the spring rate of the Eibach springs, you should be running Bilstein B8 Sport Shocks with those springs.
    https://www.bilstein.com/us/en/product/bilstein-b8/
    The B8 Sport shocks are specifically designed for a lowered sport spring set up.
    Oct 23 2015
    Australia
    Quote Originally Posted by shreddykrueger View Post
    Ah,okay same wheels I think on Heidi ?( A4 s-line option rotors here ) I didn't readily recognize them in all black...
    Quote Originally Posted by rcprato View Post
    Interesting,I was thinking that could be it (although my shocks have done 60k ml and wouldn't be the greatest ).I was talking with another member here and the B8 is the shock he recommended and fitted.
    Fronts and rears in B8's cost the same as a set of Vogtland coilovers and going down that route I would have height adjustability which is pretty important to me if I put the 18" Alzors on which have a lower o/all height...I'm at minimums with the Eibach's now.
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    You just gonna post porn on the forum like that without a warning? My gawd man think about the kids!!
    This car is what I look like on the inside
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^Been running Vogtland since 2012. Just updated the front coilovers with a fresh kit after 8 years of hard use. Great product.
    Oct 23 2015
    Australia
    Quote Originally Posted by A4 Centaur View Post
    Great recommendation ,Did you fit them yourself ? I only ask this as I'm wondering whether Vogtland supplies all rubber perches etc.They're pretty scant on info on their w/s.Did you have to supply anything not included ?
    I seem to remember when I fitted the kit to my B7 I need a few bits....after 7 years I'm a bit foggy on that though
    Jan 30 2018
    Rochester, NY
    When I helped my son install Vogtland coilovers on his GTI you had to supply your own dust covers, bump stops and upper shock mounts.
    If the A4 has over 80K miles I would suggest you buy new bump stop and upper shock mounts when installing the coilovers or even if you just replace shocks and continue to use the Eibach springs. Hopefully when the Eibach springs where installed they changed to the short front bump stop, if not you could be hitting that regularly on compressions.
    Feb 14 2016
    S4 Avant
    Quote Originally Posted by ZERO FRAME GRAB View Post
    my bad man, ill be sure to fire a warning shot next time
    S4 Avant (6MT)
    Senior Member Two Rings HOJeepster's Avatar
    Aug 04 2014
    Lyons, CO
    I hope to see this in Denver someday soon, sick!
    Feb 14 2016
    S4 Avant
    Quote Originally Posted by HOJeepster View Post
    I’m in Lyons occasionally riding (mountain bikes), so might see you around up there!
    S4 Avant (6MT)
    Oct 23 2015
    Australia
    Thanks,no I'm below that mileage and her life so far probably would have been sealed road city driving.Car had no stone chips or underbelly gouges to speak of.Heidi's in pristine condition.
    Incidentally,you guy's may think that driving here is pretty hard-core but from what I have learnt from this forum over the years seeing how your suspensions age and wear,we last longer in that regard.Sealed roads are pretty good over here,and no salt.Most of the population is in the coastal fringe with few cars like ours in the outback-that's Toyota Landcruiser territory.
    I've probably driven in half a dozen US states over the decades so have a vague feel for things over there.
    Short,long bump stops ? What would these be
    https://www.fcpeuro.com/products/aud...mper-8k0512131
    Could you please enlighten me on this ? Not sure if I've hit anything hard enough in the week of ownership to feel any bump stop impact but not doubt I will find something massive to hit eventually
    Jan 30 2018
    Rochester, NY
    You need these in the front (72mm) https://www.fcpeuro.com/products/aud...per-8k0412131f or OEM https://www.fcpeuro.com/products/aud...vag-8k0412131f
    Some have successfully cut their rear bump stops because a shorter one is not available off the shelf, you can find the info in this A4 forum's search.
    Jun 05 2009
    Scottsdale Arizona
    ^ The Vogtland Kit comes with fresh bump-stops.
    At least my kit did that I purchased a few years ago (Fall 2019) from a sponsor on here who said they were "in stock" after a huge drama I got the kit and had a great shop here in Scottsdale install them a few weeks ago.
    Lusso Motorsports gets two thumbs up for their work and attention to detail.
    Also installed fresh lower control arms from FCP Euro and adjustable uppers from SPC.
    Jun 05 2009
    Scottsdale Arizona
    I have read previously that Vogtland, KW and Bilstein use a bigger dampening rod than some other manufactures. I don't know for sure but the rear rods are thicker than Koni Heavy Duty rear shocks as I had one leak after about 5 years of heavy use (hauling stuff, track days etc.) Replaced the rear units with the Koni's.
    Oct 23 2015
    Australia
    I see,finding specific info is sometimes difficult on here-there's so much good info,I find I get sidetracked way too often !
    You had a good run from the looks of it.I looked up that number on your old dampener and came up with this using Google translate :
    https://translate.google.com/transla...75_1436-10.pdf
    A wealth of info here for those interested,looks like an approval certificate.As hard as I looked I couldn't find any info specifically for that dampener number ie rod dia etc-
    Why is the Koni rod longer in the last pic ,is it because the old one is collapsed and has no gas pressure ?
    My Vogtlands on the B7 weeped slightly since day one,V/L said this is normal when new but they never really stopped ( I wiped them whenever I had the wheels off ), doesn't seem to affect the dampening though,they're still working well.
    Aug 04 2014
    Lyons, CO
    Is it pretty safe to say that the Vogtland kit for the Allroad is too low in the rear and its advised to get the KW 30MM spacers? I'm not looking for a slammed look, maybe a 1.5 inch drop F/R and a comfy sporty ride.
    Justin | '14 Allroad | CTS K04 | CTS DP | ECS IC | APR Tune | Magnaflow | E85 | Vogtland 968116 | Macan calipers |
    Feb 14 2016
    S4 Avant
    that has not been my experience. its the same kit for a4 avant/allroad and I can't imagine the specs between the two wagons are very different. ride height has been optimal for me all the way up (shitty Denver roads mountain driving etc), and I've never thought the rear was to low.
    S4 Avant (6MT)
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Another vote for Vogtland coilovers. After riding in A4 Centaurs’ Avant I eventually decided to swap from the Bilstein B12 kit to Vogtlands and couldn’t be more happier. Great bang for the buck for someone who doesn’t track their car. Considering a set for my S4.
    And like Centaur said, you don’t need new bumpstops, the kit I ordered from AJUSA (direct from factory) came with new ones.
    Cheers,
    Ry-man
    Oct 23 2015
    Australia
    Quote Originally Posted by CONative View Post
    Hey Ry-man thanks, another great recommendation .Do you recall if you bought the avant set instead of the sedan's as Achtung ms recommends here:
    https://www.achtuning.com/vogtland-9...r-kit-audi-b8/
