One car I had was a first gen Neon DOHC, prepped to be a track monster. It had a 2.0 with stock compression, stand alone efi and the turbo from an SRT-4 (they bolted right up).
On a modded SRT full boost could be achieved at about 2800 rpm on the 2.4l engine. On my modded 2.0 with the lower displacement and shorter stroke the same boost level was achieved around 3200 rpm.
I had the turbo (turbine), manifold and downpipe coated and with a little bit of tuning we were able to achieve the same boost at 2600 rpm and sustain it much closer to the 7,500 rpm redline we set than prior to coating.
I’m a huge fan of ceramic coating, btw.
When I go stage 2 on the RS3 I’ll get a second hand turbo and have them both coated before installing.
