Results 1 to 14 of 14
    Junior Member One Ring
    Feb 18 2021
    IL
    P0322/Crankshaft Position Sensor???
    Hey all,
    Wondering if you could lend your expertise to me. 2008 Audi A4 2.0T bone stock. I replaced the CPS about a year ago, no the car does a crank but no start and is throwing the P0322 code. Could it be possible that the sensor is bad already? If not, what else could be causing that code. Pretty new here, but have enjoyed learning a lot from the archived threads. Thanks.
    Feb 15 2016
    Cambridge,Ontario
    whats the code description , we dont have them all memorized yet
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    It could be the CPS, the connector/contacts to the CPS or the wiring to the CPS. Have you checked all that?
    That code is no signal from CPS if I recall, so start with obvious.
    Have you pulled CPS out and inspected?
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Feb 18 2021
    IL
    Sorry, the P0322 code description is no signal from the engine speed sensor.
    Feb 18 2021
    IL
    Quote Originally Posted by Older_not_Wiser View Post
    All of the wiring looks good, as does the connector itself. I was waiting to pull the actual sensor because it is such a hassle. I guess that should be my next step. But, what could I tell visually by inspecting the sensor itself? I already ordered a new one, I just wanted some experienced input if there could be some other issue. Thanks.
    Feb 15 2016
    Cambridge,Ontario
    If you think that's a pain you better sell the car before your coolant flange fails
    Odd thing is I've had the cps fail in a b7 twice. Absolutely no codes at all.. just instantly morphed my car into a FORD
    ( FOUND ON ROAD DEAD )
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    when you have no related codes it cranks but it just won't start the crank position sensor is always a great place to start
    1976 Yamaha XS 360
    Feb 18 2021
    IL
    Ha! I place the CPS just slightly easier than the godforsaken diverter valve though!
    Feb 18 2021
    IL
    Thanks Theiceman. I ordered another one, I was just curious if anyone here had that code show up with any other culprit.
    Feb 15 2016
    Cambridge,Ontario
    Yeah I'd be curious too.
    1976 Yamaha XS 360
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    I just got that stupid electrical signal to fuel system code and replacing the crank sensor fixed that.
    So id say replace it. They're cheap anyway.
    Sent from my SM-G981U1 using Audizine Forum mobile app
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Feb 18 2021
    IL
    Thanks for all of the input. I have a new sensor coming tomorrow. I will update if anyone is interested.
    Feb 18 2021
    IL
    Update - it was the sensor after all. I guess that 14 months is the life expectancy for them. Thanks for all of the help.
    Feb 15 2016
    Cambridge,Ontario
    Thought so, you just got a bad one. They normally last many years.
    1976 Yamaha XS 360
