I have a higher mileage B8 S4 and have been slowly building it up. Recently I ran into quite a few issues so I thought it might be helpful to post a bulk list so people dont have to run through the forums for hours finding a solution. Im currently stage 1 APR with a cold air intake and stock exhaust with test pipes and I have about 130k on the clock. If I missed or need to update something let me know.
Issue #1
Motor Mounts: No engine code
The stock motor mounts on these cars will eventually go out or leak because they are hydraulic from the factory. These will cause other VERY expensive issues if they are not fixed relatively soon (break the cat flange). I went to a couple local shops and they all quoted me about 3-4 hours for this issue generously . Simple and relatively cheap repair. Motor mounts will run you about $430 and you can either get billet or cushioned depending on your preference. I personally went through FCP Euro because they promise a lifetime guarantee so if they do go out, I at least have some hope.
Issue #2
Catalytic converters: P0420, various misfire codes.
This was the biggest headache personally. I went stage 1 APR August 2020. About 3 months later I start getting misfire codes that will not go away. I thought it might be spark plugs so I bought new NGKs and gapped to .034 which was ~ recommended spec (down to personal preference everyone will have a different opinion). That did not work so I replaced fuel injectors with redcaps. More expensive but needed to be changed anyways. Found out after scouring the forums for what could be wrong that the catalytic converter was most likely blocked/melted (even stock S4s can melt the catalytic converter with hard driving and high mileage). Did some ratchet work and stuck some wire up from the downpipe so I didnt have to pull the whole cat out. It worked for the time being and let the melted cat breathe a little. After some time, the motor mounts let the engine shift too much and snapped the flange. Definitely recommend strengthening the weld if you get the chance. Replaced with test pipes, put some o2 spacers and no codes so far. 2021 EPA made it impossible to find a tuner other than 034 motorsport to get a test pipe tune unless you go APR ultracharger (may change in the future). I used JHM test pipes and had the shop inspect the weld because these can sometimes break as well. 16 hour repair later (blocked cat melted bolts to manifold) and she purrs.
Issue #3
Mechatronics unit: P0751, P0753 (Shift Solenoid code) Usually only affects B8 models as this seems to be fixed on B8.5 and up.
Car started shifting rough from 2nd 1st and would occasionally get TMPS & Gearbox Malfunction which I would just shut the car off and turn it on and it would work normally. Had local stealer look at it quoted me $2k to replace mechatronics unit. This issue is relatively common on B8 transmissions. Some cases you can get DSG tune on it and a gearbox mount replacement ($50) and it may be fixed. Mine eventually threw P0753 and stopping and starting would not fix. This means the mechatronics unit went out so you can either drop it off at a stealer and hope you get a $2k mechatronics repair (was quoted around $5-6k by other stealers) or buy the mechatronics repair kit from ECS (which is a audi/vw genuine part) and install it yourself (many local Audi shops refused to install). Install takes about 3 hours and requires you to pop the bottom of the trans off. Link to DIY who did it (Mechatronics repair kit is done, with a little DIY......... (audizine.com)). Not terrible to DIY but hard if you dont have a lift. I had a local shop referred by the stealer (Matrix Integrated, Oregon). They did the whole repair for around $1400. Certain transmissions depending on manufactured year uses plastic gaskets which break when you take them off so keep that in mind if you DIY.
Issue #4
Tire wear issues.
This is my first real performance car and had no idea about the amount of camber on these cars so bear with me if this is common knowledge. I had a pair of $400 Nokian winter tires that came with the car and I did around 20k with them in less than a year. Found out inner edge was wearing faster than the rest of the tire. Split the sidewall from the tread and had to replace. When you rotate your tires, have the shop flip the tire so the outside goes to the inside.
Issue #5
Control arms (specifically front)
If you notice creaking from your car when you turn, your control arms are most likely going out. Easy and cheap repair. These go out faster than normal cars so if youre like me and this is one of your first Audis keep this in mind.
Edit:
Did a cross country drive at apr stg 2 dual pulley and had another random issue. @145k miles
Issue #6
Oil cooler gasket leak
I had a seeping leak for a while and never paid too much attention to it. After the trip I noticed that it was dripping oil from the pan and found that it sheared two of the bolts off the cooler. Replaced gasket and bolts and no more leaks.
Apologies for the longer post just want to make sure people know what they are getting into when they get a nice deal on a B8 S4.
