Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56 5F
62 6C 72 A9
Mileage: 68210km-42383miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CTUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07---
Coding: 0A190034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
ROD: EV_ECM30TFS021_AU48.rod
VCID: 3A2D3955ECD4E86B817-806E
1 Fault Found:
6262 - Idle Control System RPM
P0507 00 [104] - Higher than Expected.
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 9
Mileage: 67718 km
Date: 2021.01.24
Time: 12:23:16
Engine RPM: 788.00 /min
Normed load value: 4.3 %
Vehicle speed: 0 km/h
Coolant temperature: 108 °C
Intake air temperature: 62 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.624 V
Unlearning counter according OBD: 37
Engine speed: actual: 768 /min
MAF_ENVD: 119.83529 mg/stroke
Coolant temperature (unfiltered): 96.75 °C
Ignition angle: actual: -9.375 °
MAP_1_ENVD: 366.15820 hPa
TPS_ENVD: 0.0 %
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Revision: -------- Serial number: --------------
Coding: 281D1A01
Shop #: WSC 06325 000 00000
VCID: 094F9699F93233F3D8D-805C
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 JM HW: 8K0 907 064 JM
Component: BCM2 2.0 H14 0650
Revision: 00002001
Coding: 0F814040000000000000
VCID: 045187ADDE106E9BABB-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 0214000070944009
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Component: KLIMA 3 ZONEN H04 0122
Revision: C1000000 Serial number: 01110420142088
Coding: 6600228000
VCID: 77ABE0619FC63503BE9-8022
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000786677402
Coding: 26000091863CAFE0240048C300003D0D0F9C9308A209022100 0008004000010200040030000000
VCID: 7AADF955ACD4286BC17-802E
Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B Labels: 1KX-955-119.CLB
Component: MITSUBA250314 H18 0461
Serial number: 1403200703551
Coding: 004577
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22496454
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000204141633
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555RB51103
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 06B88227000000000001
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Component: AirbagVW-AU10 H48 0610
Serial number: 003KJDC076LF
Coding: 303844354730303030304A55304C384B3053
Shop #: WSC 47996 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4ACD6995BC3478EB117-801E
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000JP7Q
Crash sensor for side airbag: driver side:
Serial number: 6334MSME443C51046
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME4438207EG
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME2440434CA
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME54453B40E
Crash sensor for front airbag: driver side:
Serial number: 63732SME4C402150R
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME564A2D4AB
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NDA000PL
Coding: 000016
VCID: 44D147AD9E90AE9BEBB-8010
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 983 HW: 8K0 920 983
Component: KOMBIINSTR. H35 0564
Revision: 00100000 Serial number: ZAI58494F
Coding: 8BB509008B01D705020000
VCID: 72BDD175F4A4502B897-8026
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z144040C34
Coding: 80C303FF00
VCID: 4CC16F8DB6C066DB23B-8018
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 8933663003
3 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 67713 km
Time Indication: 0
Date: 2021.01.24
Time: 11:54:00
Freeze Frame:
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 00000
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 67713 km
Time Indication: 0
Date: 2021.01.24
Time: 11:54:00
Freeze Frame:
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 00000
03158 - Control Module for Information Electronics 1 (J794)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 67713 km
Time Indication: 0
Date: 2021.01.24
Time: 11:54:00
Freeze Frame:
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 00000
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 000104140001413
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F3B180127963DC3269-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0077
Revision: AA000000 Serial number: 00000097775738
Coding: 00581B00000000000000
VCID: 3B233C51E36ED1639A1-806E
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0330308617
Coding: 010211
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_AU21.rod
VCID: 3FDB4841F7F6CD43B69-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0332105917
Coding: 010211
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C13204E00410001
VCID: 56F58DE5780C2C0B85F-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 G HW: 8K0 909 144 B
Component: RCEPS H40 0508
Revision: 00001000 Serial number: 0003455273
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 008015
ROD: EV_RCEPSAU48X_008.rod
VCID: 35372A69C5CA07136C5-8060
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0331989177
Coding: 0106063A00FA404580B0013200000000
Shop #: WSC 12345 123 61029
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000825021
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
3 Faults Found:
01503 - Bulb for 3rd Brake Light (M25)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 67713 km
Time Indication: 0
Date: 2021.01.24
Time: 11:53:59
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 67715 km
Time Indication: 0
Date: 2021.01.24
Time: 12:16:39
02615 - Fuel Tank Cap; Lock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 67730 km
Time Indication: 0
Date: 2021.01.24
Time: 17:56:05
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
VCID: 55F78AE9650A27138C5-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H01 0005
Revision: -------- Serial number: 10000000360961
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0305
Coding: 010C13204000210001
VCID: 59EF86D909120373A8D-800C
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-J4290SQ
Coding: 1000006
VCID: 3829235DDE58FA7B773-806C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0305
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 140325201137
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
VCID: 72BDD175F424502B897-8026
End----------(Elapsed Time: 01:44, VBatt start/end: 14.4V/14.6V)-----------
Thursday,04,March,2021,14:34:32:46875
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
