Results 1 to 4 of 4
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    ABS Module to Wheel speed sensor wiring harness
    Having some trouble finding the issue with my abs wheel sensor on the Right Front side.
    VCDS cannot pull a reading on this sensor while the other 3 sides are showing resistance and working great.
    I replaced the sensor and still nothing. When I delete the code, it immediately shows up again.
    Did some research and came across this TSB : https://static.nhtsa.gov/odi/tsbs/20...54858-2629.pdf
    Not sure if this is my issue but wanted to check if you guys had wiring harness issues before?
    Also, is there a way to check with vagcom if there is power going from ABS module to wheel sensor.
    Any way to check with vagcom if the ABS module is faulty?
    Thanks in advance.
    Garage:
    B5 S4 Santorin Blue Stage 2
    B8 A4 Premium Plus
    D4 S8 4.0T
    Jul 16 2018
    Atlanta
    If I wanted to validate circuit connectivity to the wheel speed sensor, I'd pop the plug off the ABS/ESP control module (the big plug on the brake hydraulic unit next to the coolant reservoir) and check continuity of the following:
    T38a/22 to G47 (front left) pin 1 - yellow wire
    T38a/34 to G47 (front left) pin 2 - red wire
    T38a/33 to G46 (rear left) pin 1 - white wire
    T38a/20 to G46 (rear left) pin 2 - black wire
    T38a/18 to G45 (front right) pin 1 - green wire
    T38a/6 to G45 (front right) pin 2 - black wire
    T38a/31 to G44 (rear right) pin 1 - yellow wire
    T38a/20 to G44 (rear right) pin 2 - black wire
    Issues with the joins of the wheel well wiring to the main harness are not unheard of.
    If I wanted to test the sensor itself, I'd swap it with the one from the opposite corner of the car. So swap front right with rear left (opposite corners use the same sensor).
    If the wiring rings out good and the sensor works fine in the opposite corner, that would seem to leave just the ABS/ESP control module. Which is not the cheap conclusion.
    Mar 15 2012
    Quote Originally Posted by Smac770 View Post
    If I wanted to validate circuit connectivity to the wheel speed sensor, I'd pop the plug off the ABS/ESP control module (the big plug on the brake hydraulic unit next to the coolant reservoir, and check continuity of the following:
    Issues with the joins of the wheel well wiring to the main harness is not unheard of.
    Smac770 Thank you. I will look into this tomorrow. I appreciate the input.
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Mar 15 2012
    Image1615122200.642001.jpgImage1615122207.411810.jpgImage1615122217.662333.jpgImage1615122225.493477.jpg
    Thanks for the help. I was able to find an old repair job on the wiring and it looks like this was the cause.
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
