Results 1 to 30 of 30
    Junior Member Two Rings
    Nov 02 2018
    Pa
    Audi RS3 brisk spark plug
    Everyone, I currently have a stage two RS3 with NGK plugs but looking to change to Brisk spark plugs as they are a lot cheaper and I hear great things about them.I use pump 93 in the winter and e85 in the summer .Who has experience with them and can I get the spark plug number ? Mileage they last?
    Thanks
    May 23 2016
    Edmonton
    They need to be regapped frequently. I used them on my Golf R and the gap widened (.024 to.028) within 7500km.
    Mar 09 2018
    2018 RS3
    I would think they are not as durable as iridium plugs. You would have to service them more often.
    Florett RS3+DS1+034TCU
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Stock NGK's are still the way to go
    Stage 1 more than you RS3
    Nov 06 2017
    Vancouver
    Quote Originally Posted by o1turbo30v View Post
    I truly don't know why people just don't buy NGK for everything. They have been doing it a long time and their products are typically dead nuts reliable.
    Veteran Member Three Rings jd_rs3's Avatar
    Dec 18 2018
    Longmont, CO
    why cheap out on spark plugs? If you're that worried about the cost of spark plugs, not sure RS3 is the best car for you. Just really don't understand the desire to do this when NGK's do just fine.
    2018 nardo gray rs3 - sold
    Nov 02 2018
    Pa
    I come from a supercharged s550 running Brisk plugs never a problem usually change them every spring. I would do the same on the Audi just want opinion on people who have run them looking for a slight edge if even possible. any feedbacks appreciated not looking to hear the Audi is Not the car for me or not
    Nov 02 2018
    Pa
    Dec 18 2018
    Longmont, CO
    Hence my comment. It was not intended to be offensive.
    Junior Member One Ring RSRSRS's Avatar
    Jun 23 2019
    Gilbert, AZ
    I have the same question because there is no way I am spending $40 for a spark plug. I just can’t do it. I’ll replace the silvers every year if I have to.
    Iroz recommended them to a stage 2 friend of mine. He loves them and ran a [email protected] (faster than any of my stage 2 friends). He bought the Silver ER10S’s in case you were wondering.
    2018 Audi RS3
    1/8: [email protected]
    1/4: [email protected]
    1/2: 162.8075mph
    Mods: 034 Midpipes, 034 Dogbone, CTS FMIC, Uni 4” Turbo Inlet, IE 4” Intake, APR catless DP, Uni port injectors, Uni Stage 2+ ECU, Uni Stage 2 TCU
    May 23 2016
    Edmonton
    I say they're good and last 10-15000 miles in my experience. You just have to check them frequently to regap them. If you're ok with that then go for them.
    Nov 09 2020
    Dallas TX
    Just ordered the colder NGKs
    Veteran Member Three Rings Jeff_Jeske's Avatar
    Nov 24 2018
    Madison WI
    When trying to decide which way you should go .... think about the criticality of the part you are shopping for. What kind of abuse does this part see, how often is this part used, is it a key ingredient in the recipe for engine health and performance, is changing to an untested alternative worth the risk?
    The Brisk ER10S is $11x5 = $55
    The NGK 7437-9 is $40x5 = $200
    The difference is about $150 over the course of a year (I change mine every spring). My time alone is worth more than that to NOT have to change the plugs as often!
    Unitronic has the NGK plugs in stock which you know are authentic NGK. I'm not a UNI nuthugger but they do have one of the best shipping and supply chains out there. I just received my spring resupply which arrived 3 days after placing the order.
    Dec 18 2018
    Longmont, CO
    Jeff, pretty risky coming into this thread with all your logic and reason nonsense. We're here to save $
    Nov 24 2018
    Madison WI
    Quote Originally Posted by jd_rs3 View Post
    Sorry man. I'll work on being better.
    Feb 04 2019
    Georgia
    Anyone compared the NGK to Denso iridium?
    About the same price. Seen in a thread here, or maybe somewhere else, that the NGK's had a "defect" or something that would cause the tip to break off or something. I've always ran NGK's in the past, but something about a certain model number of plug are weird.
    Thoughts?
    Nov 24 2018
    Madison WI
    I recently saw a facebook thread about an NGK tip issue and I immediately thought to myself I wonder if those plugs were manually gapped and how it was performed.
    As far as I could tell, I only saw one person that said it had happened to them.
    Many of us have been running the NGK 7437-8 iridium plugs in EVOs since 2006 without issue. It's basically the same 26.5mm reach plug just one range hotter. The price of these hasn't changed in over 15 years.
    Nov 09 2020
    Dallas TX
    Quote Originally Posted by Jeff_Jeske View Post
    Jeff, I just got my NGKs 7437-9s today. I'm currently running uni stage 1+ on stock plugs for the past 500 miles. When changing out the plugs this weekend should I change the gap set in the box? I've heard that keeping the wider gap brings in more power. If changing it, what's the optimum gap for this setup?
    Nov 24 2018
    Madison WI
    Every NGK plug I have received has been within spec and needed no adjustment.
    Nov 12 2019
    Why does everyone get so offensive when someone wants to save a buck ? Though I personally don't think trying to penny pinch on a critical component such as a spark plugs is wise. Better off telling the op why you think x is better than y. Instead of the f-off post.
    I purchased NGK for my stg 2 e85 rs3, if a reputable retailer had a sale and I could save you bet I would take the deal like many of us would.
    OP , like others have said better to stick with NGK, less maintenance and trusted brand. I ran NGK and brisk in my s550 and my s197 , much prefer the NGKs. Brother currently has a 8second supercharged s550 , we run NGK.
    So NGK in my opinion is the choice.
    Sent from my IN2025 using Audizine Forum mobile app
    Dec 18 2018
    Longmont, CO
    F off post? Who? What post are you talking about?
    Sent from my Pixel 3 XL using Tapatalk
    Sep 12 2020
    SC
    the NGK's come pre-gapped to 0.028, Unitronic(and APR) say to gap them to 0.024 +/- 0.002.
    How are all the ones you receive within spec? or are you gapping them to something other than 0.024?
    Nov 24 2018
    Madison WI
    Experience has taught me not to re-gap any precious metal plugs. I can promise you that people have done much more harm than good attempting to change that gap a few thousandths.
    There are videos of people using those little round gapping disks pressing on the electrode, others with serrated jaws pliers and even some fool whacking the plug strap on a hard surface to close it up. These are not lawn mower plugs and shouldn't be treated as such.
    The tuners recommendations are a good place to start but with a healthy coil on plug ignition system .028 is fine for stage 2 power levels. If you are skeptical just log the car afterwards to ensure you don't have any misfires.
    Mar 09 2018
    2018 RS3
    I believe the factory gap is 0.028" but with higher boost/cylinder pressures, the gap should be a bit smaller to prevent spark blow out. I usually gap plugs on turbo cars at 0.024" - 0.026" and gone down to 0.022" on 2015 WRX with FA20DIT.
    I agree that some don't know how to gap plugs properly and end up damaging the center electrode.
    Sep 12 2020
    SC
    gotcha. i agree, gapping them properly is important. i would be curious to see how they run at 0.028, if theres much of a difference.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    First time in my life hearing a brand brisk for spark plugs and I have been on many vendors and tuners websites, Napa, autozone, orellys,pep boys. Where are brisk made?
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Nov 01 2017
    Waco/TX/USA
    The Denso 5347 IKH27 plugs directly cross reference the NGK R7437-9 per NGK's cross reference guide. Both are iridium, but the Denso plugs are half the price. With the NGK's being hard to come by today, does anyone see why I should not go with the Denso's? They are same price as the Brisk's as well.
    Jul 09 2020
    Michigan
    I am seeing mixed reviews on gapping....I really dont want to try and re-gap the plugs if I don't have to. Is it safe to say that attempting to regap from 0.028 to 0.026 is not worth the risk?
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by wittmer25 View Post
    Denso over Brisk anyday. Densos are good to go, just make sure you buy them from a reputable re-seller, lots of counterfeit issues with them.
    Mar 09 2018
    2018 RS3
    I have a set of Brisk plugs sitting here. I think I might gap them on the tighter side to account for wear.
    I've always wondered if anyone ran Denso IKH27. I would think they would work fine but I often hear stores about Denso ceramic insulator cracking.
