Results 1 to 22 of 22
    Feb 18 2018
    nola
    Why all the akebono ceramic pads luv?
    I installed new rotors and akebono pads last weekend. I’m underwhelmed by the pads performance compared to stock(much less initial bite, no noticeable improvement in stopping power). My experience is on street only, so can’t speak to fade resistance. But just daily driving, the akebono ceramic pads are average at best....with the exception of brake dust.
    Any better pads out there for dd ?
    Thanks,
    W
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Very little brake dust....
    Senior Member Two Rings Jmstrag's Avatar
    Aug 15 2010
    Yes no brake dust and less initial bite is a positive for me.
    I hate the grabby feel of German brakes. The light tap of the pedal and you get jerked forward in your seat. I like the more linear feel of the pedal with the akebono. The harder you press the harder it brakes.
    Sent from my Pixel 5 using Tapatalk
    Senior Member Three Rings BEight SFour's Avatar
    Oct 13 2019
    Alpine White E36 M3.. RIP rear ended
    Bay Area CA
    With ceramic pads and/or rotors isn't their peak performance at certain temps?
    With my pads I notice they don't bite at all when I first pull out the driveway and I have to step a little harder, plus they'll squeal a little. Theb after a few stops signs they'll start to pick up more bite.
    I'm rubbinf Q5 brembos with ceramic pads from ECS
    Sent from my SM-G975U using Audizine Forum mobile app
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Quote Originally Posted by Jmstrag View Post
    +1
    and no noise like the god awful stock pads
    love them
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Established Member Two Rings Atrevido's Avatar
    Mar 19 2018
    Florida
    For those looking for an upgrade over OEM pads, the Akebonos are a simple, solid choice. They offer less initial grab and a more linear response to your input. No noise.
    I wash my car every week and with the OEM pads it got really frustrating to see brake dust build up in only 2 -3 days. With the Akebonos the brake dust is almost entirely gone.
    Yes, there are numerous other manufacturers out there offering quality pads. For my (non-tracked) daily driver, this was an excellent choice.
    2013 S4 / 6MT / Phantom Black / APR Stage II Single Pulley / Sports Diff / RS4 Grille / Sachs Performance XTend Clutch / ECS Lightweight Flywheel / ECS Transmission Mount Insert
    ECS X-Pipe / K&N / Modded Air Box / CR-15 / Osram CBI 5500K HID / Zimmermann / Akebono / Pirelli P Zero AS Plus 3 / Hard-wired Valentine V1 Gen 2
    Senior Member Three Rings KLX's Avatar
    Jan 28 2018
    Shaw AFB SC
    Quote Originally Posted by Atrevido View Post
    +1
    2021 S5 Premmie SB 034 intake & springs/034 Stage 1
    2018 S5 Prestige SB Sold
    2015 S4 B8.5 APR Stg2 DP Sold
    @businessklazz on Instagram
    Established Member Two Rings Glacier_S4's Avatar
    Jun 24 2020
    US
    Running these with Macan calipers. Mine continue to squeal 6 months after installing whether I’m driving 5mph or 70mph; freezing temps or 60 degrees. Little brake dust though.
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by Glacier_S4 View Post
    Did you use an anti-squeal paste?
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Huge drop in dust build up and a much better feel, in my opinion. Stock pads were too grabby and touchy. I much prefer a more linear and progressive feel and the Akebonos deliver this.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Jun 24 2020
    US
    Quote Originally Posted by evanb View Post
    I have. Twice actually. Rotors are OE Parts from ECS.
    Dec 25 2019
    Howell, MI
    I just got me some Raybestos street performance pads and rotors. Good quality and not super expensive.
    Apr 09 2017
    Murfreesboro, Tennessee
    Love them here. No noise, dust, and no jerky first bite. Great all around. Ran them on stock brakes and the Q5 calipers I have on now( no noise, sorry to hear about yours Glacier).
    Nov 29 2019
    Cincinnati
    Something must be off with your setup, I’ve run this same thing since July 2020 and there is ZERO noise on mine.
    Senior Member Three Rings audigsr's Avatar
    Jul 09 2016
    I love my akebonos over stock due to the less initial bite. It was hard to brake smoothly when parking in the garage with oem, no problem with akebonos. Also, I've never seen my wheels so clean for so long. That alone is worth it to me. The braking performance from high speed braking feels the same to me vs oem, and easier to modulate and control.
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    I'm running Hawk 5.0 up front (with Zimmerman rotors) and I really like them. Designed as a high performance street/light track duty pad. They squeal occasionally (very rarely) and dust is low. I would recommend at least taking a look if you're considering making another change. And if you do, might as well bump up your fluid to something with a higher boiling point to take full advantage.
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    I stick with Pagid semi-metallics, Zimmermann Coat Z rotors, and ATE Typ 200 Fluid. I hate loosing the initial bite when switching to ceramic pads. I ordered everything from FCP so if I ever start to get noisy brakes I can just replace them for free with their lifetime warranty (I've been running my current set for 2 years and I rarely hear a squeak).
    On our T3 Touareg I tried the Akebono Ceramics and ditched them after towing. I just didn't have the confidence that I did with the OE compound. I had to mash the brake pedal when stopped facing downhill to keep from inching forward.
    There's definitely more dust than the ceramics. But performance trumps aesthetics for me when it comes to braking.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Apr 04 2012
    MSP
    Quote Originally Posted by willomd View Post
    Thanks,
    W
    Yeah I used Akebonos for years.
    I'm not a fan anymore.
    Very numb brake feel, no initial bite, outright dangerous performance in the winter or cold wet weather.
    I've since moved to Hawk performance ceramic pads. The brake dust is pretty low.
    Nov 28 2017
    Carbondale, IL
    I won't use ceramic pads--with multiple vehicles, I have experienced ceramic pads leaving deposits on rotors, which results in pedal judder. On every car that's had that problem, I've resolved it permanently by switching to semi metallic pads and bedding them in (10 hard almost-stops from 60ish mph).
    I am using Raybestos Element3 pads on my S4 currently. They have good stopping power, good bite, low dust, and no noise. https://www.rockauto.com/en/moreinfo...309881&jsn=439
    --'11 Audi S4 Prestige, 6MT, boring white
    --'15 Audi A4 S-Line, 6MT, volcano red - wife's daily
    --'03 Mustang Cobra vert, '02 Porsche 911 Cabrio, '94 Caprice wagon, '23 Cadillac CT5-V Blackwing, '17 Corvette Z06
    --'08 Buell 1125R, '05 Speed Triple, '99 VFR800, '15 Vmax, '02 DRZ-400E
    Feb 18 2018
    nola
    Thanks for all the responses! Knowledge is power. I 'll try a different set of pads after i wear thru these....or until I can't stand them anymore.
    What a great community!!
    thanks,
    will
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    thanks,
    will
    You can also try out Porterfield R4-S Pads
    I run them on all my cars now - not a true Race Pad - but a great performance DD Pad - never found any issues with them
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    I too have been using the Hawk HP 5.0 pads for the past 20k miles on my DD. When its time to replace them, I'll go with those pads again. Low dust, extended wear, easy on the JHM rotors, linear pedal feel, good stopping power, and they play well with our ABS. I tried a couple of pads that just did not get along with the ABS and my braking "style".
