Originally Posted by
Robscoe
Okay before I say anything IÂ’m going to start with the fact that I donÂ’t have the time, or mechanical know how (I work 75 hours a week) to take off the manifold and I donÂ’t feel like paying for it to get done as of now. I know it doesnÂ’t work as well as that but itÂ’s better than nothing. IÂ’m looking to do the throttle body/vacuum method but IÂ’m not sure which would distribute it best. IÂ’ve been told Liqui-moly is possibly the best, would love opinions, and again, yes I know manual cleaning is the best. I know a lot of folks say sea foam and the like do nothing at all (which evidently isnÂ’t true it does some just not as much as manual) also, is it essentially pointless to run anything through the gas tank since itÂ’s TFSI? Thanks
Given that you don't have time or interest in self-cleaning of valves manually, the best option is to find the closest local shop that offers BG Products GDI (gasoline direct injection) Performance Services.
No in tank, or even consumer "suck through the induction" chemical solution is going to do much to the hard crusted baked on carbon on the back side of intake valve on direct injection engines.
I've done valve direct injection valve cleaning with chemicals (manifold removed, valves exposed) with Chemtool B12. It works, still requires time consuming scrubbing with brushes. Messy. Also done walnut cleaning. Works better, but needs an adapter plate to keep the walnut and loose carbon in place.
Unless you can find someone to do the direct manual cleaning, find a BG Performance local shop with the equipment or have your Audi dealer ($$$$$$) do it.
