Results 1 to 8 of 8
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    how to test supercharger intercoolers for leaks
    I wonder what’s the easiest way to test the intercoolers, especially when they are not leaking like sieves. I took my supercharger off today, and the driver side bank has mostly dry carbon buildup on the intake valves, but the passenger side buildup seems to be wet. Cylinder 3 even has very small amount of liquid. I don’t see any pink flakes yet. I tried to connect a garden hose to the supercharger coolant lines, but didn’t see any leaks coming out of the ICs. Most likely, not enough pressure and I didn’t seal the lines.
    Established Member Two Rings cees's Avatar
    Oct 08 2011
    denver
    I tested mine the same way after my intercooler went out. Had coolant buildup in cyl 3 and coolant puddle in there as well. I tested it the same way I just put a pair of needle nose pliers on the other coolant hose to build up some pressure and noticed a small leak in mine.
    Apr 23 2019
    CA
    Quote Originally Posted by cees View Post
    Bingo! I forgot that I got a set of pinch off clamps somewhere. I need to find another piece of heater/coolant hose because the one which connects the metal pipes to the supercharger doesn’t fit my garden hose.
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Cover one hole and blow/suck on the other one with your mouth. Not even kidding.
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Apr 16 2019
    I’ve attached a piece of garbage disposal hose to each port. Plugged one hose, and connected the other one into the pressure test kit I’ve rented from advanced auto.
    Veteran Member Three Rings toastsauce's Avatar
    Apr 08 2014
    Jersey City, NJ
    Vacuum bleeder
    Sent from my SM-G986U using Tapatalk
    2014 Audi S5
    034 Stage 2+ ECU & TCU | 75mm TB | Ported SC | Roc Euro CAI | Merc Hx | B12 Pro Kit | 034 Rear Sway + Links | 034 Motor Mounts
    JHM Test Pipes | EC Alu Kruez | CR-15 | EC T&B Diff & Trans Mounts | USP SS Brake Lines | EBC Yellow Stuff Pad | BP Slotted & Drilled Rotors
    Apr 23 2019
    CA
    I was able to use AutoZone cooling system pressure testing kit to leak test my supercharger intercoolers. I inserted on of the adapters which came with a kit into one of the rubber hoses and plugged another supercharger hose with a plug which can with my replacement engine. I pumped it up to about 1.5 bar aka 21.7 psi (I think more like 21 psi) and checked back in 10 mins. It looks like ICs held the pressure just fine, I don’t think there was any pressure drop:
    I used the same specs service manual says to use to test the entire system - pump up to 21.7psi, if no more than 2.9 psi drop after 10 mins, pass. The caveat here is they want you to pressure test the hot system and 2.9 psi drop is what they say is going to be caused by cooling.
    In any case, looks like my ICs are NOT leaking, and the valves on cyl 3 are likely wet with engine oil. Need to understand how normal it is to have a small amount of oil there. After all, pcv is blowing the oil into the intake all the time.
    Feb 21 2017
    Denver
    Here's me testing my intercoolers:
    https://imgur.com/a/DT2nrhh
    Need to be real careful removing them. I screwed one of my up gently hammering it out, fortunately it was already leaking so it didn't matter.
